#31 |
CC: B18 c6
ECU: dta
#32 |
Informative car sharing
#33 |
CC: B18 c6
ECU: dta
little up date engine bay is pretty much ready for paint and then i can start to build back up for the last time
![]() also the engine is all together less the alternater. ![]() ![]() ![]() ![]() |
#34 |
CC: Type R
ECU: Hondata S300
Hi Miniwade. Very nice build so far..
Looking forward to seeing it on those wheels. Question - what is the length of your TB from the head to the bellmouth? Cheers Dodge ![]()
Re-build diary starting soon[/COLOR[/COLOR]] - Rust never sleeps does it!!! |
#35 |
CC: B18 c6
ECU: dta
#36 |
CC: Type R
ECU: Hondata S300
#37 |
CC: B18 c6
ECU: dta
#38 |
CC: Type R
ECU: Hondata S300
Thanks for popping out to the shed in this weather
![]() Thats actually a pretty good length. Did you have to cut that amount out of the bulkhead because they are straight (as they should be) or are you allowing for quite a deep airbox? From what I can gather 25mm over the trumpets would be a minimum. I am thinking of ITB's but don't want to cut the bulkhead (if possible) on my replacement shell. Cheers - Dodge (Ian)
#39 | |
CC: B18 c6
ECU: dta
![]() Quote:
i have cut quite a bit out of the bulkhead to allow for them (hope its enough) not sure what to do filter wise yet pic of what i have cut out ![]() ![]() |
#40 |
Very nice think of doin this to mine r superchange . Can not make my mind up . How think is that steel u have used on bulk her 1.6 r 2mm ?
#41 | |
CC: B18 c6
ECU: dta
![]() Quote:
if my car doesnt make 160+bhp i will be disapointed and will eiher put a b18 in it or supercharge what i already have. i just want to get the car altogether first then i can swap and build the perfect engine to suit my needs which will be trackdays and a little blast on a weekend, i wouldnt turbo it though as i think that would be the wrong application for what im trying to achieve. |
#42 |
Good luck . I have a b16a2 engine in mine runnin lots of skunk 2 parts . 172bhp . So yrs should be around the same plus more with sum luck . If I win lottery this winter will be supercharging it and remapable ecu system too . =}
#43 | |
CC: B18 c6
ECU: dta
![]() Quote:
as said if i make 160 ish bhp i will be happy ![]() |
#44 |
CC: B18 c6
ECU: dta
little update
![]() i have managed to drop the engine in and test fit to see everything is going to clear and thankfully its as it should be, even the aftermarket manifold will clear which i wasnt expecting so thats a bonus, also my alloy fuel tank has arrived and collected my fibreglass doors so plenty to get on with now, just wish the bloody weather would warm up a bit ![]() a few pics ![]() ![]() ![]() ![]() ![]() ![]() and one of the the drivers door fitted ![]() now i know everything is all clear i can take it apart and get the bulkhead ready for paint ![]() |
#45 |
Nice looking build!
Thread Tools | |
Display Modes | |
