Old 28-02-2013, 02:31 PM   #361
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
Looks like a fairly standard Nipon Denso unit, should be loads on ebay. Have a look for the ND part number on it.
Old 28-02-2013, 02:31 PM   #362
if you wont run the fan direct from battery did you note the pully size on the exchange unit, you northern boys
Old 28-02-2013, 02:37 PM   #363
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
Why would I want to look on eBay? This one isn't even a year old.
Paul
Old 28-02-2013, 02:41 PM   #364
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
To find the spec's, see what it should be putting out?
Old 28-02-2013, 03:04 PM   #365
Hayling mini
Hayling mini's Avatar
CC: 1340
ECU: Haltech
The Swift setup is expecting 14.4 Paul, one of the problems I have been having on my white Mini was the Alternator. When ramping up the boost it obviously needed more fuel & the power was dropping off at the fuel pump, this meant I was not getting enough fuel to run higher boost, complete raspberry to find
Old 28-02-2013, 03:25 PM   #366
DarrenW
Guest
Posts: n/a
IIRC you swapped to DTA setup.
Are you are mapped off the TPS ? with no idle control valve.
As a result the revs are dropping due to the extra pull on the alternator and as a result on the engine(speed/revs) therefore slowing the engine down.
I had this on my red mini, when I put the air con and lights...IIRC Steve(map man) had to put in more advance and fuel at the very low end of the revs, to just about 'catch the engine before it stalls'.
The other option you have is to increase you idle speed.
If I have read what you said above correctly
EDIT WE LOVE VIDEOS < . ! . >
Old 28-02-2013, 03:46 PM   #367
PaulW
PaulW's Avatar
So did you fit another higher output alternator Jerry? Or is my new alternator melonsed ?
Paul
Old 28-02-2013, 03:49 PM   #368
PaulW
PaulW's Avatar
Yes it using TPS as load and yes i have no idle valve. I have an IACV ready to fit but i don't want to........as there is loads of setting to mess with such as PID values
I will take a video Darren but it will only show the engine stalling
Paul
Old 28-02-2013, 03:57 PM   #369
Hayling mini
CC: 1340
ECU: Haltech
Paul
I just fitted another GTI one that we had, mine seemed to be charging the battery, but just ran out of power when needed to supply more juice. What was happening with my car made no sense at all, I was maxing out 550cc injectors & a Walbro 255 at 250BHP
Old 28-02-2013, 03:59 PM   #370
PaulW
PaulW's Avatar
But i haven't got anyway near the demand your talking about?
Paul
Old 28-02-2013, 04:17 PM   #371
Hayling mini
CC: 1340
ECU: Haltech
Paul
I am not saying its 100% the problem you are having, but its a possibility, bear in mind when my car is being mapped not much would be on. Worth checking, to eliminate it
Old 28-02-2013, 04:30 PM   #372
PaulW
PaulW's Avatar
I'm thinking about not worrying about it too much and living with it
But then again I'm also think about the Cuba Libre I'm about to drink
Paul
Old 28-02-2013, 05:45 PM   #373
Brumski
ECU: Mini Tec uprated Honda
Paul - does the engine have an Idle control and is the DTA set up to use it?
Old 28-02-2013, 05:52 PM   #374
PaulW
PaulW's Avatar
keep up Carlos
Paul
Old 28-02-2013, 07:43 PM   #375
Hi Paul,
These are the bad boys you need to reduce rpm and make your 1st usable.
I will try to get you a set.
They have 72:19 teeth.
Atchi
