Old 03-02-2018, 06:47 AM   #1
Mini Vlatko
Mini Vlatko's Avatar
Default Cable shifter on F18/F20
Did any of you guys managed to fit cable shifter?
I can see that MarkGTT used it and it is doable but his build thread is abandoned and there's not much detail about it...
I started to consider it lately and beside the better aesthetic look of the shifter itself, is there still need for that bulkhead box?
Old 03-02-2018, 07:57 AM   #2
Bernard used it in his too
Burnard's 998- 1600 8v build
https://r.tapatalk.com/shareLink?sha...5&share_type=t
Old 03-02-2018, 09:42 AM   #3
Mini Vlatko
Cheers for that but non of his pics work
Old 04-02-2018, 04:07 PM   #4
wee man
wee man's Avatar
Vectra c f17 gearbox selector needed. I think you can then use Astra j vectra c 5 speed in car selector and cables. That's what I'm gonna use on mine. I'll update as I get round to it
12.71@108.44
Old 04-02-2018, 05:21 PM   #5
Mini Vlatko
Well it appears that I'll be hitting the scrap yard tomorrow and I'll try to source the parts for install...wish me luck!
Old 04-02-2018, 05:28 PM   #6
The selector in the gearbox is something like 4 bolts and just pulls out, dead easy from what I remember
Old 15-02-2018, 06:35 PM   #7
wee man
wee man's Avatar
Sorted mine used vectra c f17 gearbox turret and metal gear cable bracket. Then used Astra j 5 speed gear stick and cables. Works mint.
12.71@108.44
Old 15-02-2018, 08:31 PM   #8
wee man
wee man's Avatar
https://ibb.co/eUeq0n[/IMG]
12.71@108.44
Old 15-02-2018, 09:02 PM   #9
wee man
wee man's Avatar
12.71@108.44
Old 15-02-2018, 09:02 PM   #10
wee man
wee man's Avatar
I can't post pics for bananas ��
12.71@108.44
Old 16-02-2018, 06:12 AM   #11
Mini Vlatko
Here it is!
Huge
Old 11-10-2018, 08:20 AM   #12
scottpottinger
scottpottinger's Avatar
Can you use any vauxhall 5 speed shifter? Can't seem to find any astra 5 speed. Mokka one on eBay with cables.
Does this give a better shifter position ,as it can be mounted lower?
scottpottinger is offline   Reply With Quote
Old 11-10-2018, 08:32 AM   #13
wee man
wee man's Avatar
Yes can mount lower. Astra j 5 speed will fit. 2010 on astra. So long as its 5 speed
12.71@108.44
