Old 28-01-2018, 10:55 AM   #1
Default Using Mini Speedo with vtec gearbox
It looks like it's possible to used off the shelf parts to connect a Clubman/later Mini speedo to a Honda gear box.
What you need is a Rover 200 (one with the Honda D series) speedo cable and rubber grommet (long thin one at gearbox end of cable - they are sold separately but are assembled in the photo below)
Part numbers in photo
If you have a early cable clutch box this is all you need
If you have the later hydraulic clutch box then the speedo drive is electronic however internally its the same as an earlier drive so can be adapted.
The earlier boxes have a metal speedo drive converter which the VSS bolts on to. This will need to be replaced with the drive parts from a cable clutch box or a later plastic VSS modified as follows:-
1) Using a round file, file a groove just below the VSS connector
2) Using a hacksaw, cut the VSS connector off - IMPORTANT do not cut across the sensor. With the sensor held upside down in a vice (speedo drive end up) make 4 cuts down onto the connector at 90 degrees apart so that you leave a square of plastic above the groove you've just filed.
3) Using a flat file, file the square in to a circle a little smaller than the body of the sensor and then file it in to a wedge shape. Don't go too mad as the plastic is not very thick here
The rubber grommet can then be eased on to the VSS and then the cable slotted through and connected in to the drive in the sensor. The grommet is a tight fit so its easier to fit the cable after the grommet - Just make sure you engage the end of the cable in the speedo drive properly. You can check this by turning the speedo pinion gear and the speedo end should turn with it
On the other end of the cable you need to cut 110-120mm off the rubber tube covering the cable otherwise you won't be able to fit the bulkhead grommet.
On the body you need to open up the speedo cable hole in the bulkhead to an egg shape to fit the Rover 200 grommet that's fitted on the cable
IMPORTANT NOTE - Modding the VSS as above removes the VSS signal and so if you are using the standard Honda ECU you will find the vtec will not engage as it requires a VSS signal. This mod works with aftermarket ECUs that don't rely on a VSS signal or ones that it can be coded out on. If you are using a standard ECU then further work will be required. The usual work around is to fit a reed switch in to the Speedo head to produce a suitable signal which can then be wired in to the VSS wire(s) to the ECU. This has been covered in old threads but I've not looked recently as to how detailed these are
Edit - http://www.16vminiclub.com/showthrea...ht=reed+switch is a decent thread that might assist re mimicking the VSS
Build Thread - Standard Round Nose B series AWD build using MGF subframes has begun
Old 28-01-2018, 11:09 AM   #2
The Mini speedo will read low by about 10-15% depending on FD and wheel size and will need recalibrating but this can be done by Speedy Cables
Old 28-01-2018, 12:48 PM   #3
GEORDIE SP1
GEORDIE SP1's Avatar
Nice work OZ, means you can use the early cable honda instrument panels also.
GEORDIE SP1 is offline   Reply With Quote
Old 28-01-2018, 04:15 PM   #4
I'd just note that the work I've done is based around a RHD Mini, you'd need to check cable length and clearance on the plenum for LHD
Old 28-01-2018, 10:29 PM   #5
fynnbar
fynnbar's Avatar
Subframe: SAE
ECU: Standard obd1-P30
Sticky !!
fynnbar is offline   Reply With Quote
Old 29-01-2018, 09:37 AM   #6
Very true and this retains the VSS signal so doesn't need any further mods to make vtec engage
Old 29-01-2018, 09:38 AM   #7
Originally Posted by fynnbar View Post
Sticky !!
I have asked for Admin approval to sticky the thread
Old 29-01-2018, 12:24 PM   #8
Ken555
Ken555's Avatar
CC: 1590
ECU: PW0 with custom map
What we/I need is a system that keeps the VSS signal and allows a cable drive.
At the moment, I have the cable system and a reed switch inside the original Smiths speed.
Ken555 is offline   Reply With Quote
Old 29-01-2018, 01:32 PM   #9
I don't think that's possible going by the way the VSS is made, I think you are using the only way it can be achieved.
I'm using DTA so it does away with the need for a VSS signal
Old 29-01-2018, 02:07 PM   #10
Sticky !!
Approved and I've edited the first post to take in to account comments re the VSS signal
Old 10-05-2018, 02:55 PM   #11
Looking at doing this mod soon. Does anyone know if the Hondata S300 ECU has the capability to code out the VSS requirement for vtec engagement?
Old 11-05-2018, 08:16 AM   #12
keitht
CC: 1615
ECU: Hondata
Send a message via AIM to keitht
Yes you can configure vtec engagement criteria with the S300.
keitht is offline   Reply With Quote
Old 06-12-2018, 03:20 PM   #13
Georgetaberner
So it is possible to keep the smiths clock with an Honda engine, I have seen on another forum someone has used a rover speedo cable with an adapter mad engine by a company called brantz, has anybody used this? Cheers
Georgetaberner is offline   Reply With Quote
Old 06-12-2018, 04:28 PM   #14
Which Smiths clocks do you mean as Smiths made the old centre speedo and the later 2 and 3 clock in-line Clubman clocks. It's only later did Rover move to the Nippon clocks.
If you mean the older clocks then you would need some form of adapter or there is now a company that does an electronic speedo that looks like an old Mini centre speedo but takes pulses from a sensor rather than a cable. That might be an option for you. I don't think they are particularly cheap though.
Old 06-12-2018, 04:29 PM   #15
https://www.digital-speedos.co.uk/ga...eedometer-p328
/\/\/\/\This
