Old 29-12-2008, 04:39 PM   #31
Richspec
Default Bonnet and Scuttle
Next I realised I'd grapesed up
The old bonnet was distorted and even with the new ABS one which was a lot better quality the bonnet sagged at the back edge of the engine bay as the original lip had been removed.
So i had to cut one off a scrap mini (pickup!) and weld it on as best as I could.
During:
After:
Youtube Channel
Old 29-12-2008, 05:03 PM   #32
XEValver
XEValver's Avatar
CC: 2048
this is impressive
although... your door mirrors are the wrong way round :P
Old 29-12-2008, 05:15 PM   #33
Richspec
Default Interior Paintwork
Anything insde had to be removed and i started the massive job of cleaning up the interior, rubbing it down and priming it ready for my interior coats of paint. ( I had agreed to do the inside to cut down on the cost of the respray)
Every inch of rollcage tubing needed rubbing down, welding splatter under the primer removed etc etc. Major ballache
Youtube Channel
Old 29-12-2008, 06:10 PM   #34
Richspec
Originally Posted by XEValver
this is impressive
Thats so I can check my hair as I'm working on the engine
Youtube Channel
Old 29-12-2008, 06:39 PM   #35
Richspec
Default Paint - everywhere!
Ok, the inside was rubbed down and primered as good as i could get it, I'm fully aware its a track car but it needs to look ok on casual inspection.
So onto the red paint...
Pedal Box area, a real pain to good coverage around.
Ist coats inside.
More paint.
It takes loads of coats from different directions to get in all the holes/behind the bars.
My lighting is a single halogen inside and extraction of overspray/fumes is a hoover.
The front end got some extra holes for cooling, the slam panel was perforated and the wings were cut up and an edge formed, plus a layer or two of primer filler and colour on the front where it was very short of paint from the first time.
Minor fettling (but time consuming) included fitting of the arches and the old rear boot as none of the fibreglass ones fitted very well.
The rolling shell was then trailered up the road for some paint and bodywork.
There it underwent a lot of panelwork, much more than anticipated, there was a lot of rippling in various panels, and the primer was reacting to various contaminants in the paint. I suppose I should have taken the outside back to bare metal and then sent it, but you live and learn
The engine, frame and all suspension components were shrink wrapped at home to eliminate overspray issues.
And i left it there for a month or so...no hurry!
Youtube Channel
Old 29-12-2008, 06:57 PM   #36
matt
matt's Avatar
ECU: Mems 3 Z&F
Nice looking mini. Im liking the lightening holes.
What do you mean by the fibre glass boot lids not fitting properly? Where they flimsey or was the shape bad. Just being noisey because i was going to get one .
Rover no show and all go!!!!!
Old 29-12-2008, 08:28 PM   #37
Richspec
I had three and they were all a bad shape, not matching the curve of the boot. I did find that after the respray when re-assembling with a seal that the metal one wasn't too good either
I had to physically bend it more to seal properly.
In my mind the metal one was more secure, at the time I was thinking 'road car', now I'm thinking 'track car'
Youtube Channel
Old 29-12-2008, 08:52 PM   #38
Richspec
Default Even more updates!!! Back from paint..(lots of Pics :) )
Well it was eventually ready and I went to pick it up...
Back Home..
In the garage.
Youtube Channel
Old 29-12-2008, 08:55 PM   #39
undecided on your choice of color (yes, im one to talk) but think it would look awesome on a hot sunny day all polished up! Just a case of sticking all the nice bits back on now?
Old 29-12-2008, 08:59 PM   #40
Richspec
Yep, I'll do that on the next update, I'm getting square eyed being on here most of today!
The roof is amazing in sunlight, but this will need respraying.
(You'll see why )
Rich
Youtube Channel
Old 29-12-2008, 10:13 PM   #41
caveman
caveman's Avatar
CC: 2.1
ECU: dta
Send a message via Yahoo to caveman
Default richs mini
hi rich just wanted to say top mini this is one of the first 16v mini,s i ever saw witch inspired me to build mine i still have the mag it was featured in,in april 2004 front cover glad to see you your keeping it redhot, keep up the brill work adam
anymore projects and im a dead man so the wife say,s
caveman is offline   Reply With Quote
Old 29-12-2008, 10:17 PM   #42
Richspec
Cheers Adam
Youtube Channel
Old 30-12-2008, 09:29 AM   #43
MINI_BOY_IAN
looks amazing but your gonna be grapesed when you drop a screwdriver or the loose change from your pocket rolls in under the rear cage webbing
2.0ltr 8valve road legal track biatch
member of the torque steer wrestlers federation
MINI_BOY_IAN is offline   Reply With Quote
Old 30-12-2008, 10:22 AM   #44
mininut
ECU: Trionic 5.5
That's very shiny indeed, you turning into a show boy now??
M.
Old 30-12-2008, 12:04 PM   #45
Richspec
M.
Its one of those ten feet specials unfortunatly..
Needs various parts re-done and full polish to get s**t out of paint
But i will be showing it a lot locally.
Youtube Channel
