Old 27-05-2014, 09:15 AM   #196
Aubrey_Boy
Running creams (Bosch Part 0280 150 744) at 3 bar and above really isnt a problem, I've run them at 3.2 / 3.3 bar in my last XE and they ran for several years this way, yes they run at 2.5 Bar in a std 2.5 Motronic.
But it's done widely in the industry with these and lots of other injectors without issue, I've tested creams and blues from 2.5 to 4.0 bar and neither showed any sign of giving up the ghost, it's not a linear gain but if you just need a little more cc/min it saves the cost of new injectors and remapping on them as you will have to completely re do the fueling
I've seen injectors which in OEM spec run at 5.0 bar but ran without problem at 10 bar for extended periods in race engines, It's an extreme example and not one I would suggest without proper and knowledge testing but running a bar or so above standard isn't usually a problem.
Obviously just in the same way that an injector running at the 2.5 Bar pressure would need to be checked it pays to flow test / visually check spray pattern of injectors to rule this out as if there's a problem it will still be there at higher pressures.
It is also said to help fuel atomization - but that's beyond my engine knowledge / understanding
Old 27-05-2014, 11:16 AM   #197
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Rich I have a set of refurbed creams you can borrow if you want to try a different set. I've swapped to blues so they're not being used
Old 27-05-2014, 09:29 PM   #198
Richspec
thanks i'll bear that in mind when i get back onto it.
Youtube Channel
Old 30-04-2018, 11:26 PM   #199
Richspec
Still on with this, although I've been busy with 5 and 8 port builds recently, obviously some update posts have been lost but I'm aiming to be out this coming weekend for a big test session, although theres a lot to get sorted. This is the first video from when i decided to start the recommission process.
https://youtu.be/Gyj-QhL3das
Youtube Channel
Old 09-05-2018, 10:48 PM   #200
Richspec
latest vid from saturday and its dyno time for the old xe.
https://youtu.be/ee9X1M9HmbI
Youtube Channel
Old 10-05-2018, 09:24 AM   #201
Had an issue with brake lights staying on before, was a faulty switch behind the brake pedal, if I remember correctly there is some adjustment on them too, you can move it forwards and backwards to make sure it sits in the correct position, you need it touching the pedal when your not braking and then when you start to brake it should immediately come off the switch.
Old 10-05-2018, 03:11 PM   #202
Richspec
Thats (almost) what it is! Fault 1 is the switch is loose on the bracket that holds it against the pedal. Fault 2 is the sidelights came on when the brakes are pressed! Came not come as it didn't do it late on on Sunday.
Other issues!
Front coilovers spring platform locking grub screw not tight and was unwinding (I think)
Leak at connection into offside front caliper
Hydraulic Handbrake works too well, cant even get to first notch
Rear nearside coilover needs lifting up as that corner sits low.
Driveshaft binding (suspected) due to being too long on nearside.
Exhaust blowing at front joint
Youtube Channel
Old 10-05-2018, 11:16 PM   #203
Glad you got it out again Richard,
The standard of this is breathtaking ,,
Makes me wander why I bother , lol
The red tops return ,
Old 11-05-2018, 10:23 PM   #204
Richspec
Yep, i can finally see the potential thats sat doing nowt for far too long, the dyno session was the turning point, then the first sighting laps at Blyton frantically adjusting the brake bias, all positive steps forward that only testing can highlight. But of course it gives me another list to work through.
Youtube Channel
