Old 23-06-2014, 06:52 PM   #46
l_jonez
ECU: Megasquirt and ITB's
Been a very long time since a update, the project has been on the back burner for a few years. But in the last few months we've got on with it again.
The subframe has had a redesign, a new smaller alternator has been fitted.
The drive shafts are the last major part left and they have been finished today
Faced off to length and the Honda shaft turned down and a sleeve made.
Two halves welded together and the weld turned down flush.
Sleeves slid on
Then welded
Also bought some 2mm gasket material (aluminium core) and made a new inlet gasket.
Then plugged the loom etc in and fired the engine up and run it until normal temp to make sure the cooling system works and there was no leaks etc
Old 20-08-2014, 08:51 PM   #47
l_jonez
Well today the engine fell into the frame
Old 21-08-2014, 12:15 AM   #48
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
more pics of the alternator bracket
Old 01-05-2016, 11:49 PM   #49
l_jonez
Looks like a few posts have been lost
Basically the following has happened since the last post....
Shafts built up
4 pots and vented disks installed
Maniflow exhaust bought and fitted ( can't find pic of it fitted)
Engine installed
Modified the gauges to move some of the warning lights
New binnacle made to match the Honda clocks
Interior wiring and sound proofing installed
Dash painted and built back up
That pretty much brings us up to date
Old 06-05-2016, 09:31 PM   #50
Jamie 16v
Fancy making me drive shafts local to you
Loving the build
Jamie 16v is offline   Reply With Quote
Old 07-05-2016, 10:43 PM   #51
Dutchy1978
Looking good. How did you mount the cluster to the new binnacle?
And did you use a new piece of flat Perspex or modify the original curved one somehow?
Dutchy1978 is offline   Reply With Quote
Old 08-05-2016, 07:38 AM   #52
l_jonez
A combination of screws and brackets. It's a new piece of Perspex.
Old 09-05-2016, 11:26 AM   #53
neca
CC: ?????
ECU: BB2
Thumbs up
Congratulations for the good work.
I'll have good ideas for my
neca is offline   Reply With Quote
Old 09-05-2016, 08:17 PM   #54
l_jonez
Feels like we're getting somewhere now
Dash is in, new steering wheel fitted as the old one was the wrong Colour and tatty. FYI the MG TF steering wheel is identical to the mpi wheel but 10% of the price.
Also the carpet has started to go in.
Old 10-05-2016, 09:02 AM   #55
Captain Slog
Captain Slog's Avatar
Is it possible to debag the MGTF or any other steering wheel? I like them but am sure one can not send courier them with airbags live.
احترام
Captain Slog is offline   Reply With Quote
Old 10-05-2016, 08:06 PM   #56
Jamie 16v
Fancy helping me do wiring on mine
Will pay etc I hate wiring
Old 10-05-2016, 08:28 PM   #57
l_jonez
Not really sure, we bought it on eBay and it got delivered no problem
Old 10-05-2016, 08:30 PM   #58
l_jonez
Sorry I just don't have the time, it's taken 8 years to get this far and I have a few other projects to get on with.
Old 10-06-2018, 10:21 PM   #59
l_jonez
Well it's been a long time since I posted on this thread, the mini has now been on the road 2 years now and except for a rad fan relay failing there's been no issues.
Mini has attended a few local events and castle Combe
