Old 18-02-2009, 05:39 PM   #31
l_jonez
ECU: Megasquirt and ITB's
yesterdays pics
spare tank
civic pump, cut and lengthed
flange cut from civic tank
hole cut in top of tank and flange welded in
pump in place
im pretty happy with the final result and it didnt cost a penny
Old 18-02-2009, 05:49 PM   #32
terryg
terryg's Avatar
ECU: rover MGF
nice job
i am going to do the same to my tank
The hole MGF in my mini lol. now on a diet
terryg is offline   Reply With Quote
Old 26-02-2009, 11:14 PM   #33
l_jonez
just realized i forgot to post the pics of the front engine steadies being made :-[
(sorry for the low quality mobile pics)
the bush mounts being made
mounting plate, holes spotted to bolt to gearbox and then steady been fabricated
( only tacked together in photo)
next pic shows it fitted or at least in place to ensure correct alignment etc before the U shape bracket is welded to frame
the other side is pretty much the same just with different shaped plate. both have polly bushes fitted. im not sure if their up to it yet ut its not a hard job to change if they prove to be to small.
at the rear im using two stock honda mounts which will be filled with extra rubber to help stiffen them
Old 04-03-2009, 09:53 PM   #34
l_jonez
finaly got around to building a crossmember today and trial fitting the exhaust manifold
i forgot to take a pit of crossmember before puting the frame back in the mini, i'll post one up next time the frame is out
did manage to take a pic of manifold clerance tho, which ime pretty happy with
also you can see the alternator roughly where it will end up being fitted, theres just enough clearance all around it plus it means i can use a standard belt and not worry about long belts and idler pullys etc etc
Old 06-03-2009, 01:58 PM   #35
l_jonez
i've been playing with radiators today and thought i'd try the half rad that came out of the civic, the width is ok but its slighty to tall
the core of the rad is knackered any way so it would need to be re-cored, so i was thinking i could get a shorter core put in to allow fitment and posibly a more efficiant core if thats posible?
Old 06-03-2009, 07:54 PM   #36
l_jonez
decided the only way to find the size i would need was to play with some cardboard, if i were to re-core the honda rad to allow the rad to fit up right it would be this size
[rubbish quality yet again]
from my calculations the core will be 29% smaller than the standard civic one, not sure if it will be up to the job :-/
i know companies claim the all alloy rads are 30-40% more efficient so in theory that would bring the the cooling ability back up to standard.
i dont think im to happy with that so i'll be doing it again tomorrow to find the largest posible size then getting quotes on getting it made
Old 13-07-2010, 07:06 PM   #37
l_jonez
today the postman delivered a new rad, its a civic alloy vti rad and it fits just need to blank off the filler and angle one of the outlets
Old 05-03-2011, 12:52 PM   #38
l_jonez
long over due update
after deciding that we didnt want to cut the bulkhead we played around with the idea of making a wedge to kick the manifold up but after sending some cad drawings to various companies the cheapest price we got was 300
we then decided to cut the manifold angle it and get it welded so off we went to www.rallyweld.com
also while we where there he altered our rad for us, the filler neck was chopped off and plated over and the one out let cut and a fresh one welded on but at an angle to allow clearance
might actually make some progress now :-/
Old 05-03-2011, 06:11 PM   #39
l_jonez
few pics of it fitted. theres plenty of room
Old 10-04-2011, 09:22 PM   #40
l_jonez
Tiny bit done earlier with the wiring. The civic loom has all ready been stripped down to just an engine loom so today I set about modifying a mini loom.
I decided to use the loom out of my mpi as it has a moden fuse box and allows the use of the later style stalks etc. So Todays task was removing all engine related wiring ....
End result
Basicly the engine loom from the civic will now just plug in
Here's how much was cut out
Shows how much wiring the injection mini uses
Old 10-04-2011, 10:34 PM   #41
GingerMonkey
GingerMonkey's Avatar
CC: 1797
ECU: OMEX 600
Good effort there. The wiring is a major raspberry for some people but looks like your doing well. I like the welds you got done on the rad and manifold. Very tidy. It's great you don't have to cut into your bulkhead. Saves so much hassle, least of all from the IVA testing VOSA people if they ever have a look at your mini. Does your rad fit in nice now? I know my filler cap is still touching the bonnet but will be living with it for a while
GingerMonkey is offline   Reply With Quote
Old 10-04-2011, 11:00 PM   #42
l_jonez
The rad fits easily but I got it mounted on its side and I'm using an expansion tank, will get some pics up soon Along with the alternator position once my idler fully turns up
Old 08-05-2011, 10:21 PM   #43
l_jonez
Slight update alternator bracket and idler pully finished. So only thing left is to sort the driveshafts
Old 13-05-2011, 09:51 PM   #44
l_jonez
Engine is now fully wired up and plumbed in, hopefully if I can pick up some oil in the moring then it can be fired up
Old 15-05-2011, 03:59 PM   #45
l_jonez
Engine fired up straight away such a good feeling
