Old 01-09-2008, 03:31 PM   #16
l_jonez
ECU: Megasquirt and ITB's
Pointless update but today we bought some 8.4" vented disks and a set of 4 pot alloy calipers . hopefully they will be able to stop the thing
Old 23-09-2008, 07:18 PM   #17
l_jonez
arrived in the post today some 4 pot calipers and 8.4 " vented disks
quickly stuck the calipers on a spare hub ( didnt bother with the disks)and theres clearance when using a standard 12"mini wheel
and plenty of space with the 12x6 revolutions that i might fit
just have to find some time to actuly do any thing on the build
Old 17-11-2008, 10:38 PM   #18
l_jonez
was just sorting my old camera and found some pics of the early stages of the frame build.
since these pics where taken the N/s engine mount has been made the bottom front to back straps have ben welded in
Old 18-11-2008, 10:57 PM   #19
l_jonez
after uploading the pics yesterday it spurred me on to dig out the frame and do a bit more
so today i finished off the engine mounts let the frame take the weight of the engine for the first time
except for some stiffener braces etc its done
will take some new pics tomorrow
Old 20-11-2008, 08:59 PM   #20
l_jonez
found some more pics
Old 22-11-2008, 01:12 AM   #21
l_jonez
managed to get the engine into the frame today, what a kuffufle
any ways some pic to show it fits ;D
got a fair amount of clerance on the pot joint so the engine can be moved back abit
the frame does sit a bit low but id rather the car bottom out and hit the frame than the sump
Old 24-11-2008, 08:55 PM   #22
l_jonez
ITS IN!!!!
well OK it fits, and things will be very tight. i do like a challenge tho
engine isn't sitting square in the frame at the moment, mainly because i was to excited to line it up properly and just bolted it down and fitted it to the mini
Old 26-11-2008, 05:18 PM   #23
l_jonez
sorted the rack clerance issue today
Old 26-11-2008, 05:31 PM   #24
Just a thought but would it be better to turn the rack 90' so that the spindle points upwards ? When you use a UJ it'll make the angle column (and the steering wheel) much flatter making the driving position much less "sit up and beg".
The Watsons set up is similar and the angle of the column is much more comfortable than a mini setup
As i said, just a though
Old 26-11-2008, 05:54 PM   #25
l_jonez
tried that first and even with a large amound filed off the body it wouldnt fit
Old 07-12-2008, 10:30 PM   #26
l_jonez
not really much to report but today i removed the fuel sender from the civic tank and modded it to fit where the original mini one does.
it was very straight forward and im pleased with the result, will post some pics when i get chance
Old 16-12-2008, 03:13 PM   #27
DarrenW
Guest
Posts: n/a
I have amended your status to club member, so you can use the gallery if you wish and see all parts of the forum
Old 17-12-2008, 09:57 PM   #28
l_jonez
brilliant, thanks, just have to try make some more progress on the build now
Old 05-02-2009, 01:38 PM   #29
l_jonez
not really much in the way of progress but today i attacked the sump
and then plated it up
i started grinding down the weld but quickly got bored and it wont really bee seen when in the car so i just primered and sprayed it up.
Old 17-02-2009, 09:38 PM   #30
l_jonez
today i took the civic's internal fuel pump out of the tank and chopped out the mounting flange from the civic tank, the flange was then welded to the top of a spare mini tank Mpi style.
with the flange in place i was able to fit the pump but with the civic having a under floor tank the pumps bracket was very short which results in the pick up point being only half way down the mini tank so the bracket was chopped and extended to place the pump at the bottom of the tank ;D
I'll get some pics sorted tomorrow which will explain things allot better.
