Old 19-06-2018, 07:09 PM   #16
Dopeshow
So just a small update. Managed to tub the rear arches this weekend. Used 2mm plate to give it some strength.
Apologies for the welding, first time I have done any in 15 years so a little rusty........It will get better!!! Nothing a good going over with the flapper wheel won't sort out.
Old 19-06-2018, 08:10 PM   #17
keitht
They're not going to fall out anyway!! I used 2mm plate as well. Good work.
Old 19-06-2018, 11:33 PM   #18
Looks tydy obviously no herb was smoked lol
Old 20-06-2018, 06:52 AM   #19
Dopeshow
That always used to be the joke Keith, "That weld aint pretty but its going nowhere"
Old 20-06-2018, 06:54 AM   #20
Dopeshow
All in the past Ardon. as you can see from the pics the only think smoking was the paint on my back quarter
BTW : Love you videos, they do make me laugh..... I'm always learning something....Like how not to jack a car up
Old 21-06-2018, 12:13 AM   #21
Boom!! I didn't realize anyone watched them,
It took me 10 attempts to get that fail lol,
YE,,HAAA !!
Old 04-07-2018, 11:40 AM   #22
Dopeshow
So just a small update. Just took my first delievery of parts. I will wait for comments about the springs, but I am going to give them a go! if I dont get on with them I will change them out for rubber cones at a later date.
Plan to drop the rear subframe this week and roll the car onto its side so I can remove all the paint / stonechip underneath and get it painted, i will also get the subframe shot blasted and painted. After reading previous builds and with advise off my paint supplier i will be using jotamastic 87 for the underside / subframe radius arms ect.
The parts above will enable me to get the rear end built up and get it back onto its wheels.
Old 04-07-2018, 11:51 AM   #23
Haz
I've got those springs. They're absolute dogshizzle. They make for a comfy ride whilst pottering about, that's the nicest thing I can say about them.
I'll be putting in red dot cones in the near future.
Old 04-07-2018, 12:54 PM   #24
Harley
Yep I put those springs in my car too - they are rubbish in a heavy conversion mini. They just bottom out/ bind up.
I'm considering putting some race springs in instead to try, otherwise I'll just go back to cones.
Old 04-07-2018, 01:15 PM   #25
Dopeshow
That's it, i'm convinced !
They are going back and I will order some Red dot cones..
Old 04-07-2018, 03:22 PM   #26
In all honesty, I would send back the Gaz shocks and switch them for some different ones, they’re not great quality and don’t perform that well
Old 04-07-2018, 05:40 PM   #27
Agree
Old 05-07-2018, 06:59 PM   #28
Dopeshow
Going to stick with the shocks but change the springs. I can change out the shocks if i need to once I have got it on the road.
I've got a fixed budget so want to spend in other areas of the build first.
Appricate the input though. Thanks
Old 08-07-2018, 06:28 PM   #29
Dopeshow
So the sun was out today, so wheeled the Mini outside so I could fit the front seats.
Nothing clever, just a simple rail for the back mounting points, I will drill them once I have a both seats in place. I pre drilled holes on the unside of the rectangular bar so i have access for a nut. I plan to drill the heel board and use rivet nuts as a fixing points.
I only have one seat at the moment which is the driverside so just trying it for fitment in the passenger side. I am really happy with the fit and I will be swapping the rails once I pick up the other seat as the recliner wheel needs to be on the inside next to the hand brake so that it clears the Companion Boxes in the rear. I am six foot and I am really happy with the ammount of leg room in the front, next to nothing in the back so there is definitely no seat going in the rear.
Old 19-07-2018, 05:02 PM   #30
Dopeshow
So just a further update. I moved onto installing the fuel tanks, wanted to go twin to increase the range and also I love the look of twin filler necks. I had two 7.5 gallon tanks, both are in good condition so I decided to try and make the RH one fit.
Got them both lined up and the RH one is way too big, so out out came the trusty angle grinder
Happy with the fit and look...
Brought a mounting bracket for the LH tank and made one for the RH out of some 30mm box section I had lying about.
I will make up some straps to hold them down later.
Going to get my friend to tig weld the tank as i'm not that confident in my welding skills.
