Old 28-05-2018, 09:09 AM   #1
Default Classic Mini Parts Minispares/ Minsport / Rover Group NEW PARTS
OK, so I am starting to sell off lots of stuff . Most of it is either Minispares or Minisport or Rover group genuine new parts in the original bags and boxes along with the parts numbers used by these companies. So it makes it easier to check against their websites for detail and current pricing.
I am pricing below their current prices and try to keep postage down. Have started listng on Ebay so may be worth adding me as a fav seller. Madminiman2016 is my seller name on there. I am not a trader, just club member and private seller but am 100% on Ebay. I have over 246!! ( 90% of them are brand new) items to shift, so will be adding ,as and when I can. There are some performance bits, lots of screws , fixings, brackets, trim, lights, brake parts. electrical parts.. i don't have a list but they are mainly smaller size items.
If you see something on Ebay that you want, just post up a message and we can sort direct or through Ebay, up to you. I usually log in to the forum each morning early, and could answer queries then. Private messages would get overloaded quickly maybe I think, so just add post to this thread.
I'm not getting out of Minis and am building another crazy one, but it will be a race car so do not require this stuff, but more on that project later...
link to 1 x Ebay item: https://www.ebay.co.uk/itm/263718063...84.m1555.l2649
Old 29-05-2018, 01:02 PM   #2
monkey
monkey's Avatar
ECU: A box of chips
Do you have a pair of new/old stock front disc hubs? Or ones in near new condition?
Clubman front bumper?
Old 29-05-2018, 08:26 PM   #3
Sorry, I do not have those items. It is mainly small items, just lots of bits. I will keep listing more on Ebay every couple of days I guess. 6 items went today... If it's something relatively interesting I'll try and post here first.
Old 30-05-2018, 09:08 AM   #4
monkey
monkey's Avatar
ECU: A box of chips
No worries, thanks for the reply.
Old 04-06-2018, 11:42 AM   #5
tbird302v8
I am in need of wings front end bits for a steel flip front, what do you have for a std roundnose? thanks!
tbird302v8 is offline   Reply With Quote
Old 05-06-2018, 07:00 AM   #6
Hi I don't have any big stuff as above. No body panels. Got some brand new amber front indicator units with the original glass lens and some plastic lens new. Bonnet badge new and cooper S badge new. I'll put some more up on Ebay soon. Been selling approx 15 items per week , which is enough wrapping and posting to do..
Old 05-06-2018, 12:03 PM   #7
Xe gear change unit by any chance?
Old 05-06-2018, 03:26 PM   #8
miniphil30
ECU: Erm none yet
Do you have any floor mats? Rover Genuine?
Small round inserts/trim that go in the door window winder?
Head lights? Full., bulbs, surrounds etc.
miniphil30 is offline   Reply With Quote
Old 06-06-2018, 04:19 PM   #9
Graham, do you have the small retaining clips that slide inside the window chrome strips on the front doors?
Like these...
https://www.minispares.com/product/C...%20to%20search
Old 06-06-2018, 06:20 PM   #10
Like these...
Most probably, because I have approx 100 or more bags of small clips and screws etc. I'll take a look...
Old 06-06-2018, 06:23 PM   #11
I sole my XE spare gear crate and rod recently and a spare B& M shortshifter. I have the std gear lever / knob I think.
Old 06-06-2018, 06:24 PM   #12
I will have to check mate. I have the window winder screws, maybe the inserts, but cant promise... No mats or Headlamps unfortunately...
Old 06-06-2018, 06:40 PM   #13
For AGoaty -
Yep I have a bag of 10 x those exact clips from Minispares in Minispares bag. How many do you want / need? Usually 65p each from MS you can have them for 40p each. Any good? Postage should not be much as v light. Let me know.
Old 06-06-2018, 06:50 PM   #14
For AGoaty -
Also v similar 10 x clips for window seal. Look the same but have 1/2 moon on one side.
Old 07-06-2018, 05:19 PM   #15
Yes I'll take a pack of those please Graham.
Send me a PM with PayPal details.
