Old 29-01-2018, 12:23 PM   #1
AWD
Default AWD K20 Build
Made a start with the K20 build now the B18AWD is 99% done.
Picked up the donor body last Saturday.. was cheap, sandblasted and ready to be cut up by me !!
So, .. we now have a body, AWD frame and a dummy K20 engine. Will get the AWD tranny this week and we can start.. Because the mini will keep his standard nose i will remove the firewall and make a new one 15cm back.
Old 29-01-2018, 05:20 PM   #2
Haz
Good stuff, I look forward to seeing this as it progresses!
Random thought... I'd love to see a mini with a central drivers seat and seeing as you're moving the bulkhead...
2nd related random thought... I also wonder if with the rear bench removed, will 2 buckets fit in an McLaren F1 style layout... Legless passengers only perhaps
Old 26-03-2018, 07:45 AM   #3
AWD
Found some time to work on the body..
Old 02-05-2018, 09:25 AM   #4
AWD
More work done so time for a small update
Old 04-05-2018, 06:20 AM   #5
AWD
Old 04-05-2018, 05:29 PM   #6
That last photo is that the front bulkhead or the new boot floor?
Old 07-05-2018, 07:49 AM   #7
AWD
Its the boot.. i didnt start work on the bulkhead. will finish the complete floor first and then cut out the bulkead
Old 07-06-2018, 09:07 AM   #8
AWD
Update
Thats where we are right now.. next week i will start with the 10 point roll cage and after that start building the front subframe and the new firewall.
Old 08-06-2018, 03:14 PM   #9
Dopeshow
Great standard of work. Look forward to updates. Sweet roll over jig by the way.
Old 23-08-2018, 02:55 PM   #10
AWD
little update.. not much done during the summer.. this winter I will be working on this project more
Finished the roll cage and made a start with creating a new firewall. the shell will be sandwiched between de front subframe and the roll cage. Ordered a diesel (N) CRV 6-speed gearbox and will star building the subframe when it arrives
Old 23-08-2018, 02:56 PM   #11
AWD
pics are a little big .. sorry
Old 25-09-2018, 05:42 AM   #12
AWD
[IMG]<img src="https://image.ibb.co/e7o9sU/93_BBF0_F0_9_E13_4_E1_C_8846_8_EA3_D0_B9093_D_min. jpg" alt="93_BBF0_F0_9_E13_4_E1_C_8846_8_EA3_D0_B9093_D _min" border="0">[/IMG]
Still working on it but winter is around the corner and will be spending a lot more time in the shop then .. its now 60% straight, still need to do the roof this weekend. then it will go back onto my welding table and start with the front frame, firewall and the flipfront.
Old 25-09-2018, 05:46 AM   #13
AWD
How do I get these pics smaller ??
Old 25-09-2018, 06:09 AM   #14
AWD
Verzonden vanaf mijn iPhone met Tapatalk
Old 25-09-2018, 06:30 AM   #15
Underhauled
my tapatalk was doing te same thing with pictures so i went back to photobucket.
