Old 23-03-2018, 12:19 AM   #31
GEORDIE SP1
GEORDIE SP1's Avatar
Originally Posted by mikko View Post
how you doin the 4x100 mod geordie?
Hi Mikko, the mini studs were cut off flush, set up on milling machine, also cut the Center from a old 4x100 brake disc, and used it to help Center holes
Old 23-03-2018, 10:36 AM   #32
mikko
mikko's Avatar
ECU: obd0
So your then drilling through stud and hub for your new hole? Im doin the same mod but im drilling out the old holes to m12 but inset 0.8mm, the 12mm hole will then encompass the whole of the old hole.
Old 23-03-2018, 05:35 PM   #33
GEORDIE SP1
Mines basically the same, used disc as a template
Then set up to drill out through old mini hole think it was about 12.7mm to take collar of stud.
Old 23-03-2018, 05:45 PM   #34
GEORDIE SP1
Attachment 8460
Attachment 8461
When you set the disc Center on the outer edge of old hole and disc hole. Almost line up then Center point comes in slightly.
Old 24-03-2018, 02:36 PM   #35
Is that in Irish ? Lol
Old 24-03-2018, 04:26 PM   #36
GEORDIE SP1
Make’s sense in my head by Jesus. ☘️
Old 24-03-2018, 04:37 PM   #37
Thank fook you saw funny side lol
Well I'm only English aren't I lol
Old 27-03-2018, 12:31 PM   #38
AWD
Hi, question! What specific vw flywheel bolts did you use. Have trouble sourcing m10x1.0x40 bolts 10.9 or 12.9! I know you found some! Let me know ��
Old 27-03-2018, 06:34 PM   #39
GEORDIE SP1
Hi, got them online, will try and hunt out supplier tonight.
Old 27-03-2018, 07:01 PM   #40
GEORDIE SP1
Got them that time from Spaulding fasteners. co. uk
Had a quick look but not able to find them this time, maybe you could email them. I think I got the 12.9 . Cheers
Old 27-03-2018, 08:30 PM   #41
AWD
Thnks buddy, Will check that tomorrow! See What i can find there
Old 27-03-2018, 09:56 PM   #42
GEORDIE SP1
Test fitting new wheels, should sit into arch nicely.
Thinking about going Gold this time
What you all think.
Old 30-03-2018, 04:17 PM   #43
vfast
CC: 15
Thumbs up gold
gold is a winner or harp or gin or corrs light
vfast is offline   Reply With Quote
Old 30-03-2018, 05:00 PM   #44
Gold spokes silver rim ? Even if you drink pish!! Lol
Old 30-03-2018, 05:29 PM   #45
GEORDIE SP1
Thanks as usual for your input guys ,going to get grapesed and let loose with a gold rattle can and see what happens
