Old 19-06-2017, 02:23 PM   #1
AWD
Default AWD rear frame
AWD rear frame, new!
Comes with custom upper control arms (adjustable) and standard mx5 lower control arms,
All PU Bushes, anti-roll bar and drive shafts. Poedercoated in any color, 2500 euro!
optional, instead of PU bushings.. all heim joints (rose joints) with custom lower control arms.
Old 17-07-2017, 11:26 AM   #2
nerdymind
nerdymind's Avatar
CC: B16
Hi mate, can this apply in all Minis? Am running B16 honda engine
Thank you
Ayman
nerdymind is offline   Reply With Quote
Old 17-07-2017, 12:12 PM   #3
AWD
[QUOTE=nerdymind;372186]Hi mate, can this apply in all Minis? Am running B16 honda engine
Yes, no problem! you can use any B or K serie engine in combination with the CRV-1 AWD gearbox and diff!
Old 11-09-2017, 01:49 PM   #4
AWD
Gen2 rear AWD frame.
Current AWD project in progress
Rear frame 2000 euro excl. shipping and drive shafts, 2500 euro incl. drive shafts excl. shipping.
Old 22-05-2018, 11:28 AM   #5
Winny
Are you still selling these?
What is the lead time and what do you do about the rear wheel PCD I assume 4x100 on the rear and 4x4" on the front?
Winny is offline   Reply With Quote
Old 22-05-2018, 04:47 PM   #6
AWD
Hi, Yes i am still selling the rear AWD frames. Right now lead time is around 4 weeks. You can use your mini rims on the 4x100 mx5 hubs by using the moving nuts. With that a max 2mm difference can be handled. But the mist best is to redrill. I use the nuts and its great for me.. if you have further questions then please let me know.
Old 27-05-2018, 08:32 AM   #7
Winny
Do the mx5 disc and calipers also clear a 10" wheel?
Winny
Old 06-06-2018, 11:01 PM   #8
stickerbomb
Any more pics of just the frame built as up to the mini rear ? And how much of the boot floor need removing ?
stickerbomb is offline   Reply With Quote
Old 07-06-2018, 08:24 AM   #9
AWD
Winny
10 inch does not fit the mx5 calipers
Old 07-06-2018, 08:49 AM   #10
AWD
Hope this will help you.. depending on what you want to do but for installing the frame you need to remove atleast 80% of the boot floor. if you tube the arches then just remove everything and start from scratch
