Old 06-06-2013, 05:59 PM   #16
sirkieran_1986
Well had a bit of fun with sum old netting and a can of equinox purple . Wot do u think . ? .
Cheers . Home made and bent , fully welded in .
www.kjbfabrications.webs.com
sirkieran_1986 is offline   Reply With Quote
Old 11-06-2013, 08:42 AM   #17
sirkieran_1986
Got the roof on . Left it over night with the lorry straps holding it down . Looks great now . Just need the rest of the body painted then seam seel around the gutter .
Old 11-06-2013, 06:36 PM   #18
sirkieran_1986
Started to build frame and line frontend up . All under a std round noise .
Old 11-06-2013, 09:36 PM   #19
1275stu
looking awesome that! Bet that roof cost a bit?!
1275stu is offline   Reply With Quote
Old 12-06-2013, 05:27 PM   #20
sirkieran_1986
yea was a lot of pocket money saved for that .
Old 12-06-2013, 06:08 PM   #21
andyfkettle
andyfkettle's Avatar
That looks smart! Worth every penny.
Old 12-06-2013, 06:30 PM   #22
sirkieran_1986
Yea love it . Bit more news have to put my build on hold just had neils build dropped off
Old 09-09-2013, 08:03 PM   #23
sirkieran_1986
should be starting on my b18 estate in the next two weeks
Old 04-10-2013, 08:45 PM   #24
sirkieran_1986
Well time to start the fun again on the 1960s estate . .
Old 06-10-2013, 07:43 AM   #25
sirkieran_1986
So the fun starts again .
Old 08-10-2013, 05:42 PM   #26
sirkieran_1986
Started making subframe and lining everything up in engine bay
Bit of help
Old 12-10-2013, 06:20 PM   #27
sirkieran_1986
Bit more work done to day . Welding frame . Goin to try and use the clutch masker cylinder down here .
Old 18-10-2013, 06:17 PM   #28
sirkieran_1986
Got the tyres on the 10x7 steels .
Old 19-10-2013, 05:50 PM   #29
sirkieran_1986
Did sum trial fitting today .
Old 25-10-2013, 02:55 PM   #30
sirkieran_1986
Down on all fours . But not for long .
