Old 22-10-2012, 03:31 PM   #16
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
how does it adjust for making sure the belt is in lign on both pulleys? any possibility of making the holes elongated to compensate for that, or are they pretty much straight from when you make it.? im pretty enterested in getting one.
Old 22-10-2012, 03:57 PM   #17
JoBu
JoBu's Avatar
I've got one, it sits straight with the crank pulley. A lot better than my previous Watsons brackets!
All I had to do was put a small spacer between adjuster and my alternator to keep the adjuster square.
JoBu is offline   Reply With Quote
Old 22-10-2012, 06:16 PM   #18
bartvtecmini
the bracket is designed so that it sits square to the pully the bracket is more like the watsons style as unsure of the subframe clearence of the allspeed frames as they have there alternator mounted higher
bartvtecmini is offline   Reply With Quote
Old 22-10-2012, 07:20 PM   #19
dangermouse691
Default brackets
hi pal u still making these brackets will be needing a set soon is so
dangermouse691 is offline   Reply With Quote
Old 22-10-2012, 07:25 PM   #20
bartvtecmini
yes can still make them
Old 09-08-2016, 06:36 PM   #21
martiniracing
These things still available?
martiniracing is offline   Reply With Quote
Old 10-08-2016, 08:59 AM   #22
monkey
monkey's Avatar
ECU: A box of chips
I'd be interested in a set if they are!
Old 20-06-2018, 05:42 PM   #23
Hayley-jayne
Default Alternator brackets
Is there any chance you could make and send me one out as soon as possible please I'm willing to pay £35 as soon as it is needed thanks
Hayley-jayne is offline   Reply With Quote
Old 20-06-2018, 06:45 PM   #24
Original post was from 2012 and the last replies which got no answers were from 2016.
I doubt you’ll have much luck.
If your really desperate then message stickerbomb on here or search for Kieran James Baybutt on Facebook, he also makes an alternator mount.
Old 21-06-2018, 07:57 AM   #25
Parrotlewis
hi, please can you let me know how I can purchase your brackets kind regards parrot.
Parrotlewis is offline   Reply With Quote
Old 21-06-2018, 08:05 AM   #26
Old 21-06-2018, 01:16 PM   #27
stickerbomb
Hello I build honda b series alternator brackets
stickerbomb is offline   Reply With Quote
Old 11-02-2019, 07:36 AM   #28
vfast
CC: 15
Default bracket
can you make me that
vfast is offline   Reply With Quote
Old 11-02-2019, 08:32 AM   #29
Just note that original post is for front mount alternators, Keiran's (stickerbomb) are rear mount (similar to the Minitec bracket), just make sure you are specific in which type you want
Old 12-02-2019, 07:49 AM   #30
vfast
CC: 15
front mount for me
let me know price with post to bt602gp
