Old 07-07-2018, 01:33 AM   #961
Ok ok , speshaly for you gimp spotters, it's not exsigting so keep your self's together, I can't find a single decent vid or close look at this coil pack any where in exsistance,
May seem simple to you boffins but I don't know?
https://youtu.be/yY_y6VDWAb0
Old 07-07-2018, 07:44 AM   #962
Black wire goes onto that pin on the coil, green is rev counter and brown is earth as you say.
Get it cranking!!
Old 07-07-2018, 04:13 PM   #963
Tar !
Old 08-07-2018, 11:58 AM   #964
Brake time from mini, had to go to work, terrible job but
Someone has to do it ,!!
https://youtu.be/ZZrusLzmT6o
https://youtu.be/twGf61DuYpA
Old 18-07-2018, 11:17 PM   #965
I should have cracked on with fire up but felt the need
To diposit some trim bits that I've been falling over,
This is the worst vidio but I can tell you it's the only one so
Far that I actually felt I had done something!!
https://youtu.be/jvXSF3vLAFM
Old 25-07-2018, 12:19 AM   #966
Disaster of the week ! I sold my old faithful Alden red mini
Dizzy to to nice chap in London
I didn't want to as I bought it new in 1987 and I find out
Today his block is A+ and it won't work!!
Yet another vid that doesn't seem any use at all apart from
I'm doing stuff that matters along my way,
It's hard to film true progress when there ain't much!!
There's lots of things I didn't say that well ,
Any advice or qwestion just ask,
https://youtu.be/J4wv00uHQMQ
Old 26-07-2018, 05:40 AM   #967
Av you got it running yet? av you got it running yet? av you got it running yet?
Old 26-07-2018, 09:46 AM   #968
Kick my peach lol
Not running, I'm sorting throttle Pedel and cable,
Carbs off again for a leak and cable,
Had to take drastic action to root cable, I think ,
Also before I put carbs back on I have a seeking
Suspition that petrol is getting in , over heavy and clonking up on compression, or similar!
Old 27-07-2018, 02:41 AM   #969
Loads of nothingness ,
https://youtu.be/MvixvWp6A7U
Old 27-07-2018, 07:57 AM   #970
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
You’ve not got the dizzy set 180 degrees out have you?
Old 27-07-2018, 08:11 AM   #971
Why does it sound like it does a rotation and then hits something?
Old 27-07-2018, 08:45 AM   #972
Is that' possible john, ? I did wander I'm not new to the phisical side but I'm new to fitting a dizzy in this lump,
Danno it sounds like it in the vid but it's not allways like that,
Old 27-07-2018, 09:27 AM   #973
Do yourself a favour and get that battery on charge and see if that helps with cranking, it does sound a little slow.
Best pic I could find for the firing order
Old 27-07-2018, 11:18 AM   #974
Thanks Daniel the battery is normally charged but I get your point that is their side exit distributor that's ok but I'm at the point where I need not to have to think it's close and it's simple,
Old 27-07-2018, 11:36 AM   #975
So I'm stuck in a traffic jam somewhere in the middle of nowhere and I discover on my phone that I can talk into it and it spells everything correctly I can't believe you lot didn't tell me the do this already so now I can just talk cabbage while I'm able to make sense to everyone oh my god you have done it now I will talk about this problem later it is simpler than it seems it's just I have three things I'm not necessarily trusting and I'm going to bang one out later hurrah hurrah trip over the penny farthing
