Old 08-09-2012, 07:08 AM   #31
Dubaidaz
Dubaidaz's Avatar
CC: 1598
ECU: MBE 9A4
Originally Posted by wilp99 View Post
not in about a month.. he's got alot of minis in that garage. litterally about 40 of them that he's working on at the same time..
Yup mine being one of them!
Old 08-09-2012, 09:01 AM   #32
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
yeah, i went there yesterday, just to shoot the shti with steve and i went and took a look at your frame and such. looks like its coming along pretty good.
sooo.. any updates on the mk1
Old 08-09-2012, 09:14 AM   #33
Dubaidaz
Dubaidaz's Avatar
CC: 1598
ECU: MBE 9A4
Off topic slightly but.....
I've got to the stage now where I have to spend a shti load of cash.
I got cold feet the other day and talked of calling the whole conversion off but after careful thought have decided to truck on.
Can't believe I need to fork out at least 3 or 4 grand on the engine to get the power up.
I always wanted to go Honda power but I prefer roundnoses (like clubbies too but mine's a roundnose) and the 1600 Vx really does fit under the standard round nose.
Old 02-10-2013, 03:09 PM   #34
den berre
Default finally - small update
Finally found some time to work on the mini. Made a bigger hole in the chassis for the inlet manifold... seems to fit now
Now I have a question: I think I need better engine mounts as they seem to be sagging. If you look carefully at the pictures, you can see that the engine mount is sitting on the bolts that hold the mount to the frame... can't be right?
Anyone can suggest good engine mounts to me? I don't need the rear mount and most kits seem to include that one
Cheers!
My build can be found here: http://www.16vminiclub.com/forums/sh...ad.php?t=22754
den berre is offline   Reply With Quote
Old 02-10-2013, 03:11 PM   #35
den berre
more pictures
Old 02-10-2013, 06:24 PM   #36
andyfkettle
andyfkettle's Avatar
Have you got the rear gearbox mount bolted and set properly? That should rock it back so your mounts are level.
Good progress.
Old 03-10-2013, 03:56 AM   #37
den berre
yep... the rear mount is bolted in a position as far back as possible.
Old 08-09-2016, 08:58 PM   #38
den berre
update time... problems with the engine mounts were solved... bought some innovative mounts.. everything rock solid now..
started on the wiring... bought some modular fuse and relay housing components... used wannago's diagram as a start...
work in progress...
File Type: jpg IMG_0056.jpg (157 Bytes, 114 views)
File Type: jpg IMG_0057.jpg (157 Bytes, 112 views)
Old 08-09-2016, 08:59 PM   #39
den berre
strange.. pictures are not working?
Old 31-03-2018, 04:48 PM   #40
_666_
_666_'s Avatar
anymore progress with this build ?
_666_ is offline   Reply With Quote
