Old 31-07-2010, 12:36 PM   #1
den berre
Default mk1 - allspeed frame
Hi folks... I just bought myself a 1967 mk1 which will be upgraded with an allspeed frame and a vtec engine... I'm not yet sure which engine I will use... still have to do lots of research...
The car is still at the previous owner... I will get the car somewhere in the beginning of september and then I will order the frame and look for an engine... can't wait to start!
Anyway... some pictures of the car!
den berre is offline   Reply With Quote
Old 03-10-2010, 06:58 PM   #2
andyfkettle
andyfkettle's Avatar
Are you going to adapt the allspeed frame to fit the mk1 shell or the shell to single bolt?
Andy
Old 04-10-2010, 06:26 AM   #3
den berre
hi andy... that's a good question... i'm not sure if i will have to adapt any of them as i asked allspeed if the frame would fit an mk1 shell and they said it will... i will have to investigate this further...
i have collected the car now and it has been put away at a friends garage... we just made an offer yesterday to buy a house with a big garage so let's hope they accept... then i'll be able to start on the project...
Old 04-10-2010, 10:02 AM   #4
spudgun
spudgun's Avatar
ECU: none
Hi, looks a lot better than mine. I have a '64 and the bottom six inches is complete rust so lots of welding required. Have done the complete floor and sills, just got the boot, rear quarters, and a few patches to do. I am going down the red top route. Good luck and keep us posted.
spudgun is offline   Reply With Quote
Old 06-10-2010, 09:30 PM   #5
andyfkettle
Reason I ask is I have a freind with a minus which uses a mk1 subframe and allspeed said they couldn't make one, interesting. Keep us posted on how you get on and I'll do the same.
Andy.
Old 07-10-2010, 06:36 AM   #6
den berre
i'll keep you posted... some more pics
Old 17-07-2011, 08:09 AM   #7
den berre
I finally started on this little machine and yesterday I removed the front of my mini. Today I will try to remove the complete subframe/engine and then I can start offering the new frame. I will pick up my B16A2 engine tomorrow. It has arrived from the UK.
Old 18-07-2011, 07:51 PM   #8
den berre
The pictures speak for themselves. This was yesterday late afternoon.
Old 18-07-2011, 07:55 PM   #9
den berre
This arrived this morning
Old 19-07-2011, 10:57 AM   #10
Mr.Mini
Hi Berre ,
I see your engine is already modified on the alternator side ( special mount ) .
Have you bought the engine from somebody who gave up his project or did you buy the alternator mount specific .
BTW Welcome and good luck .
Harald
Second place is the first loser
Subframe : Allspeed
Honda B16A1 Vtec
Mr.Mini is offline   Reply With Quote
Old 19-07-2011, 11:24 AM   #11
den berre
Hi Mr. Mini,
I bought it from a member. You can see his build thread at
http://www.16vminiclub.com/forums/sh...ad.php?t=22202
I see you are from Belgium as well? Do you have a finished car yet and do you use it on the road?
Greets,
Berre.
My build can be found here: http://www.16vminiclub.com/forums/sh...ad.php?t=22754
Old 19-07-2011, 09:18 PM   #12
Mr.Mini
Hi Berre ,
Yes I am from belgium and am in the process of building an allspeed frame into standard roundnose mini .
Mini is built to full Mini Miglia race car spec for circuit racing , albeit with a Belgian registration number plate .
Succes with your build
regards , Harald
Subframe : Allspeed
Honda B16A1 Vtec
Old 24-07-2011, 02:10 PM   #13
bennivory
the frame should fit the shell, but the shell should be strengthened, fit a sleeve where the tower bolt goes through the shell, like on late cars
bennivory is offline   Reply With Quote
Old 25-07-2011, 11:31 AM   #14
den berre
I will strengthen the shell with sleeves to be sure.
I recently bought the tower bolts and the big washers. I'm not sure if I should use some other mounting stuff between the frame and the shell or just but it together metal to metal?
I have also bought the mini spares subframe tower improvement kit but I'm not sure if it is wise to use this (see picture).
Advice is welcome.
Thanks.
Old 25-07-2011, 11:35 AM   #15
Advice is welcome.
Thanks.
you don't need that at all with the Allspeed kit.
he supply's top big washer.. and you don't have any sort of washers/rubber between the subframe and the shell.
(i do put some copper grease in-between before bolting it to the shell though)
Matt
