Go Back   16v Mini Club Forums > Classifieds > For Sale
Old 15-07-2016, 09:45 PM   #31
Kam
Kam's Avatar
Originally Posted by Stuart80 View Post
I would like to get mine done anyone know the length of shafts need for the allspeed set up
Check the link provided in the following link, there are two different lengths depending on the 'mini' end if it will be HD allspeed or just standard mini
http://www.16vminiclub.com/showthread.php?t=27941
My mini has got nothing to prove so nothing to lose
Kam is offline   Reply With Quote
Old 06-12-2016, 07:42 PM   #32
sebastiaan.keijzer
ECU: KMS
I send you a email. Hopefully you can Help me.
Thanks,
Sebastiaan
sebastiaan.keijzer is offline   Reply With Quote
Old 24-02-2017, 04:08 PM   #33
gav
ECU: Emerald
How do you guys measure ideal length? Just make sure the inner joints don't bottom out inside the joint when the shaft is completely horizontal?
gav is offline   Reply With Quote
Old 25-02-2017, 11:43 AM   #34
Birdman
Birdman's Avatar
Mock it up with a broom handle and keep cutting it to length and measuring. Just an idea..
Whale Oil Beef Hooked!
(use Irish accent)
Birdman is offline   Reply With Quote
Old 03-07-2017, 02:45 AM   #35
Bieben
Hello,what are you mian custom?
tiema TRUCK PARTS
Bieben is offline   Reply With Quote
Old 03-07-2017, 09:47 AM   #36
This is service to join two different types of driveshaft together. For example a Honda engined Mini will need Honda driveshaft from the gearbox but then a Mini driveshaft on the outer end.
Old 05-06-2018, 07:04 AM   #37
Doodling
Is this service still available?
Or is there anyone else doing it?
Doodling is offline   Reply With Quote
Old 05-06-2018, 11:34 AM   #38
That's a fair qwestion that needs a answer!
I seen a few people wanting to get hold of aband,
Old 05-06-2018, 02:45 PM   #39
PMíd you doodling, can you update this thread if you manage to get hold of him and let us know if heís still doing this service?
Old 05-06-2018, 04:34 PM   #40
Doodling
PMíd you back
Old 18-09-2018, 07:58 PM   #41
Doodling
Little update for you.
I spoke to Adam at the beginning of September and sent him my mini and Honda bearings to measure.
Tried to get in touch again last week and he seems to have gone quite or on a nice holiday.
Iíll try again in a week or two.
Old 18-09-2018, 08:20 PM   #42
Thatís disappointing.
Iíve just been to see Jamie at DRD Racing, I had an issue with the circlip groove not being deep enough to allow the clip to compress enough to allow fitment of the CV joint.
All sorted now though and although it was a long time ago I had them made, hecwas more than happy to take care of it and very helpful.
Charly had the same issue with his and had it sorted locally instead, he then snapped one and when he complained, he was given a full refund, he then went on to snap his old driveshaft in the same place so I doubt the issue was a quality issue on DRDís behalf, Charlyís broke at the weak point on the Mini shaft where the large circlip goes, in hinsoght I should have had mine made without that groove and had a shoulder machined in there like competition shafts do.
Anyhow!
Although itís more expensive than having shafts sleeved and Adam does do a great job, Iíd recommend DRD to make you up some one piece shafts, I paid £200 delivered and sent him the CVís and my old shafts to work from although he only needs the CVís to measure the splines really, especially now he knows the circlip groove is 2.3mm deep and not 1.5!
Old 18-09-2018, 08:45 PM   #43
Doodling
Sound like Iíll may have to go that route. Iím even though Iím down one Honda inner cv casing. Has anyone got one spare?
I have been quoted locally to have mine friction welded but was a little pricy to be honest.
Old 18-09-2018, 09:04 PM   #44
ECU: Megajolt
Not to belittle your troubles, but there's only about a week between the beginning of September and last week, give it time!
If you're in a rush, let him know and he'll be able to tell you whether he can fulfil it or not.
Old 18-09-2018, 09:25 PM   #45
Doodling
Miss dated sorry, meant I originally spoke to him mid June and tried to contact him again in sept. So itís been 4 ish months when he estimated a week. I have been patient and Iím not in a rush just thought Iíd update for anyone who was interested.
