Go Back   16v Mini Club Forums > Classifieds > Wanted
Old 21-06-2018, 04:05 PM   #1
andyMac
Default VTEC oil pressure switch (green)
Anyone got a VTEC oil pressure switch that fits onto the VTEC solenoid unit?
Mines in pieces... Seem ridiculously priced in UK, but cheaper in US, so thought I'd see if anyone had one on here second hand first...
Its a 1994 B16A2 engine
thanks
andyMac is offline   Reply With Quote
Old 21-06-2018, 08:34 PM   #2
keitht
It can be bypassed if that helps. I took mine off.
Old 21-06-2018, 10:09 PM   #3
andyMac
How would I go about bypassing it?
Old 22-06-2018, 08:37 AM   #4
keitht
Its just a loop between 2 pins at the ECU, i don't have the wiring diagram at the minute but can have a look later.
Old 22-06-2018, 06:42 PM   #5
Dopeshow
Hi, It's pins A4 & D6 if you have an ODB1
Old 23-06-2018, 09:07 PM   #6
mikko
mikko's Avatar
ECU: obd0
i got one i think, whats it worth to ya?
Old 25-06-2018, 07:06 AM   #7
andyMac
thanks Mikko and everyone for the advice on bypassing. This sounds like an easy solution to a broken part.
Mikko - Given the ease of bypassing I will probably try that, but if you want rid of the pressure switch let me know what you want for it and if it's cheap enough I'll have it anyway. thanks
