Old 02-12-2017, 10:22 PM   #241
joakwin
CC: 1.6
ECU: Bone stock
fuel tank by joaquinn lopez, on Flickr
in the process of adding more volume to the tank
I plan to somehow make the Honda fuel level sender and mini fuel lever sender work together, the mini mount and Honda electric stuff together I guess I'm trying to say
Old 03-12-2017, 05:50 PM   #242
Red Riley
Red Riley's Avatar
If you're already welding on the tank, I suggest you ditch the Mini sender and float and put one of these in. I'm doing this to my VTEC Elf and it's awesome. No more leaking fuel around the sender seal. Just need to weld up the existing hole and weld a flat mounting plate (included with the new sender unit) to the top of the tank. TanksInc floatless sender You need to specify what resistance range your fuel gauge uses, so you can match it to a Honda gauge, or whatever you need.
Red Riley is offline   Reply With Quote
Old 05-12-2017, 01:32 AM   #243
joakwin
CC: 1.6
ECU: Bone stock
fuel tank level honda by joaquinn lopez, on Flickr
Honda fuel lever sender with mini seal and lock
Old 05-12-2017, 05:27 PM   #244
Red Riley
Red Riley's Avatar
Did you have to modify the float to work at 90 degrees from normal? Don't those Honda float units normally mount on the top of the tank?
Old 05-12-2017, 09:38 PM   #245
joakwin
CC: 1.6
ECU: Bone stock
stock Honda is top mount
I bent it right at the cover plate and then bent the float arm
only time will tell if it will work
Old 10-12-2017, 05:20 PM   #246
joakwin
CC: 1.6
ECU: Bone stock
fuel tank in boot by joaquinn lopez, on Flickr
fuel tank sitting in the boot, still need to make a strap to hold it in
purge canister by joaquinn lopez, on Flickr
fuel lines are done, and I even hooked up the purge canister to the fuel tank and the intake manifold, I want the car to run like it did in the del slow chassis
Old 11-12-2017, 11:59 PM   #247
joakwin
CC: 1.6
ECU: Bone stock
video-1513036286 by joaquinn lopez, on Flickr
run video
Old 16-12-2017, 08:30 PM   #248
joakwin
CC: 1.6
ECU: Bone stock
I got the mini running with the Honda fuel tank now
I adapted the Honda filler neck to the mini filler neck inlet and I'm using the mini fuel tank cap
but I think the standard Honda fuel tank cap is a sealed cap
with the car running I reved the motor a few times and then
it started to pop and surge in rpm's
and then I put my vented mini fuel tank cap on and the popping from the exhaust and rpm surge stopped
I think I need to order a sealed mini fuel tank cap
Old 02-01-2018, 03:14 AM   #249
joakwin
CC: 1.6
ECU: Bone stock
sheet metal dash by joaquinn lopez, on Flickr
sheet metal dash I started to build
Old 02-01-2018, 06:15 AM   #250
DVO
DVO's Avatar
ECU: Chipped
Probably it is somewhere in the topic, but why right hand drive? Lack of space for the steeringrack?
Dennis
Old 03-01-2018, 01:31 AM   #251
joakwin
CC: 1.6
ECU: Bone stock
Dennis
my car is a uk spec
so I'm keeping it rhd
I have a lhd mini as well
Old 03-01-2018, 01:33 AM   #252
joakwin
CC: 1.6
ECU: Bone stock
13x5 wheel by joaquinn lopez, on Flickr
rims I'm looking at buying
Old 03-01-2018, 02:03 AM   #253
nice look and nice width for mini, what rubber do you have planned ?
Old 03-01-2018, 02:40 AM   #254
joakwin
CC: 1.6
ECU: Bone stock
175/50/13's
the rims are 5 inches wide, I think should help with wheel bearing life vs a -7 et 7inch wide wheel
Old 03-01-2018, 03:09 AM   #255
yes they will,, deffo,, 175,50,13 is a hard rubber like wooden block,
is there any more soft ballons tyres ?
