Old 07-03-2018, 06:32 PM   #316
Originally Posted by edk83 View Post
Thanks, I've decided it was a bit too low though.
This is after raising the coilovers a bit, still a couple of degrees too much camber.
New ride height, doesnt look as badass but now I have more than 2" ground clearance!
I'm wanting to fit 280mm discs and there is no way they are going to fit under 14" wheels, gutted as I love the orange ones I bought but needs must.
15" to test fit, with 45 profile tyres they are actually not much more in diameter then my 14 with 50 profile.
In case you need it.
Old 12-03-2018, 06:27 PM   #317
Thumbs up
Are you keeping the square steering wheel?
Old 13-03-2018, 10:51 AM   #318
Ha, nope only the mk1 came with the quartec wheel. I'm using an omp type wheel.
Current job is changing the lower ball joints as the mgf ones have too much camber. I have some rover 100 ones which have a few degrees less. Also I may slot the wishbones to allow adjustment. But first I have to drill out the stupid rivets !!
Old Yesterday, 09:37 AM   #319
So I've decided to stick with 14" wheels and the 240mm brakes, I'll add a remote servo if needed.
I've been busy drilling out the rivets on the mgf wishbones to fit R100 ball joints for less camber, might make them adjustable too if needed. The rivets have to be drilled, no way they are coming out any other way.
Old Yesterday, 11:36 AM   #320
Always best to have the nuts on the bottom. In the unlikely event they work loose its less likely the bolts will fall out and the balljoint separate itself from the lower arm whilst at speed.
Build Thread - Standard Round Nose with K series subframe build begun
Old Yesterday, 11:59 AM   #321
Yes the bolts need to go in from the top, the ones that came with the r100 joints are only 8.8 so I'm going to change them for some high tensile. I just used these to whack through the arm and joint, it's packed full of sealant which made getting them in a fight. Not a bad idea though, once the camber is set I may seal them again.
Old Yesterday, 07:02 PM   #322
I realise that you have done this to sort the camber out. A pic showing what it looks like now would help...
