Old 20-03-2007, 08:13 PM   #1
Hoser
CC: 1.6
ECU: OBDII
Default Anyone do a D16y7 install on a standard round nose?
Well, I'm going to attempt this swap, and if you've done it already, I'd appreciate some input. IE what subframe you used (if you bought one), any tips and tricks. Things to make sure you grab off the donor car..
Thanks.
Hoser is offline   Reply With Quote
Old 21-03-2007, 09:27 AM   #2
B20GT
ECU: OBD 0
Its covered in the FAQ, its also the most widely debated subject on the vtec section. Both have positives and negatives. You tell us your thoughts and we will see if your ideas sound plausible or not.
B20GT is offline   Reply With Quote
Old 21-03-2007, 12:42 PM   #3
Hoser
CC: 1.6
ECU: OBDII
Actually, it's not covered in the "who produces frames" thread. This is an SOHC non Vtec honda mill. I eventually plan to do a MiniMe swap onto the engine, but for the time being, just getting it in the car is the priority.
So if someone has done such a thing, any help is appreciated.
For instance, I found this website online, and its helped a bit.
http://minimikebc.tripod.com/
It's essentially the same thing, however, he modified the intake to clear the bulkhead. If I can get away from doing that, that would be one thing I would like to conquer.
Things like, how you solved the fuel delivery situation (getting an MPI tank??)
Im not looking for a step by step, just a few good tips to look for when I do the install.
Thanks,
Dave
Old 21-03-2007, 03:23 PM   #4
B20GT
ECU: OBD 0
Well, The engine will bolt up to any of the frames. Driveshafts ar a "gnats" smaller in OD, but geoff and allspeed will make them up for you.
Fuel delivery is either in tank MPi or in line on an older tank, but you need to plumb a return. Fuel Cell?????????????
Management, DTA, Honda, Emerald, Motec, U name it
HTH
Old 21-03-2007, 03:26 PM   #5
B20GT
ECU: OBD 0
Just to add, I dont think any two people have done a conversion the same, its one of these things where, you work with what you have, and cant really structure a hasstle free build, as there is hundreds of stumbling blocks (well, on your first conversion anyway lol.)
Old 21-03-2007, 06:32 PM   #6
Hoser
CC: 1.6
ECU: OBDII
Thanks for the tips.
Is there an ideal shaft length that the new axles need to be?
If i order them from the UK its going to kill me, so I'll have a shop round here take car of them.
Old 23-03-2007, 01:28 PM   #7
old_skool
Guest
Posts: n/a
i am doing a d15b vtec in standard roundnose other than having to mod the bulkhead a little to fit the inlet in fitting the engine has been fairly easy
i'm having a bit of a problem with the loom but i am working on a very tight budget so i have had to use bits i already had and the loom i had was cut all over the place
heres a more recently up dated project page i will update the 1 on here its just finding the time at the moment
my project
the frame i am using is 1 that 1 of the members on here (terryg) sorted out for me
Old 23-03-2007, 07:47 PM   #8
Hoser
CC: 1.6
ECU: OBDII
Nice progress. Looks like I have a challenge with regards to the intake situation. My masters are over on that side!
Time to look into finding a shorter runner intake instead of not running brakes or a clutch!
Either that or invest in a remote reservoir set of pedals.
Old 24-03-2007, 12:19 PM   #9
Joey.S
ECU: dta
Thanks,
Dave
Why not use your stock mini tank put a return line on it and run a MSD external F.I pump. $130.00can$ It works well for me.
Joe
Joey.S is offline   Reply With Quote
Old 24-03-2007, 09:59 PM   #10
old_skool
Guest
Posts: n/a
i need to change the clutch master anyways that 1 is fubar reading on other post i need a 14mm so i will have to purchase that on payday
Old 25-03-2007, 11:45 PM   #11
strudel
strudel's Avatar
You probably won't find another write up as good as MiniMike's project than his website. Very complete writeup. JS
Austin Mini Van with DOHC Honda HP
http://www.angelfire.com/droid/strudel
Honda reliability and power combined with Mini cachet and style.
strudel is offline   Reply With Quote
Old 26-03-2007, 12:54 AM   #12
Hoser
CC: 1.6
ECU: OBDII
You're right. I've been referencing both of your builds, and plan on doing a lengthy write up of my own build.
Im thinking of combating my intake issues by sourcing an ebay intake manifold, and doing some minor bulkhead modification, or getting an edelbrock victor X, because it appears to be shallow enough.
Exhaust header will probably be a modified ebay job too.
Tear down of the donor Civic begins this weekend.
Old 26-03-2007, 12:56 AM   #13
Hoser
CC: 1.6
ECU: OBDII
[quote="Joey.S
Joe[/quote]
I would rather not weld onto the tank, and avoid explosions or severe burns. But this is probably the way i will go, just with a Canadian Tire replacement fuel pump. El Cheapo!
Old 07-04-2007, 04:52 PM   #14
allminicoopers
CC: 1.6
ECU: Standard original honda ecu
i started my project on my mini . single cam vtec D16Y8
here are some pics
http://www.allminicoopers.com/vtecpics/mini.jpg
http://www.allminicoopers.com/vtecpics/engine.jpg
http://www.allminicoopers.com/vtecpics/vtec.jpg
allminicoopers is offline   Reply With Quote
Old 09-04-2007, 03:22 PM   #15
Hoser
CC: 1.6
ECU: OBDII
Where are you located in Cali?
What Subframe / Intake are you going to use? I think the Ebay OBX should be shallow enough.
