Old 29-01-2010, 02:30 PM   #1
TifosiKev
TifosiKev's Avatar
Default Antifreeze / Coolant
Now this is an embarrasing question how much and what type antifreeze is needed in a B16a2 engine. I have just spoken to my local Honda dealer and they did not know and I work in a parts dept and nobody seems to do the info any more.
Kev
TifosiKev is offline   Reply With Quote
Old 29-01-2010, 05:49 PM   #2
Pretty safe with an off-the-shelf brand, and 50/50 mix
Old 29-01-2010, 06:59 PM   #3
TifosiKev
TifosiKev's Avatar
Cheer's Fynnbarr
As the system is empty I thought it would be safe to use normal stuff but since I work in an ex Rover dealer I know the damage done to K Series when the wrong type of antifreeze is used.
Old 29-01-2010, 11:05 PM   #4
modga174
if its an alloy block use the pink stuff its got an anti carosive in 4got name (and ive got in me scooby lol). and you will need approx 2 ltrs
modga174 is offline   Reply With Quote
Old 31-01-2010, 06:43 PM   #5
TifosiKev
TifosiKev's Avatar
Cheers Modga174,
I will use the oats stuff that you put in K Series.
