Old 24-01-2010, 04:51 PM   #46
smith1380gt
Subframe: Brian Cambel
I ran a phantom grip in my A series diff with a hot 1380 in a few track days. Worked well with 12 x 5 wheels at ~13mm offset and 1 inch wheel spacers. I damaged a wheel, and switched to 0 offset 12 x 6, and the car became much more difficult to drive. I am of the opinion that the LSD plays a lot less into the torque steer issues than the wheel offset / suspension geometry and alignment settings do. By the way- Phantom grips are basically 2 blocks of hardened steel being pushed apart by springs that ride directly on the spider gears. I have to think that they put a significant amount of metal filings into the gear oil. Not good in my opinion...
How do you know when you have enough horsepower? "When you can spin the tires all the way to the next turn..." Mark Donahue
smith1380gt is offline   Reply With Quote
Old 26-01-2010, 04:53 AM   #47
norcalmini
norcalmini's Avatar
Subframe: MTB
CC: b16A
ECU: P09 with vtec mod
Send a message via Yahoo to norcalmini
After talking to many mini owners i think i have made the decision to swap out the big brake kit in the front for a kad kit that i can put some 10s on. im not going to change out the lsd yet. I want to see how changing the rims and offset will effect the car. Plus i can only imagine having a tire that has some more meat on it will make the ride better. So with that being said i will have a big brake kit for sale shortly. Minitec brake kit to be exact
norcalmini is offline   Reply With Quote
