Old 20-04-2012, 04:15 AM   #1
dredpyrt
Default Prefabed VTEC wiring harness?
I was wondering if anybody out there builds or knows of a plug and play engine wiring harness for a VTEC Mini. Ive done a search but the posts i ran across are a bit old. I dont really fear wiring but if i can find something already done im hoping it will shorten my build time. Thanks!
dredpyrt is offline   Reply With Quote
Old 20-04-2012, 09:02 AM   #2
eeae6000
Mini tec does
eeae6000 is offline   Reply With Quote
Old 20-04-2012, 01:27 PM   #3
Thetoolman
CC: 1798
It will shorten your build time, my loom is 80% finished and I have spent 30+ hours on my loom so far ...
Thetoolman is offline   Reply With Quote
Old 21-04-2012, 12:31 AM   #4
dredpyrt
Default harness
Ive seen there harness but i also noticed in some older posts that it left alot to be desired in the quality department.
Old 21-04-2012, 01:19 AM   #5
Furyof4
ECU: Neptune FTW
I think that could be said about most of their products.
Furyof4 is offline   Reply With Quote
Old 01-05-2012, 10:45 PM   #6
p1ngu32
The minitec loom is actually very good, but i wouldn't bother with their ecu the base map they put on causes running issues.
p1ngu32 is offline   Reply With Quote
Old 02-05-2012, 04:04 AM   #7
dredpyrt
Default wiring harness
I noticed in Minitecs Ebay add for the loom that it was nicely labeled. As far as the ECU goes the price tag alone has me exploring other options.
Old 02-05-2012, 10:34 PM   #8
Furyof4
ECU: Neptune FTW
I have heard plenty of complaints of its quality, especially for the price. Their ecu's are a way overpriced also considering any reputable honda tuner could make a better basemap for less.
Old 02-05-2012, 10:50 PM   #9
p1ngu32
Ive been running that loom for 3 years without the slightest issue, mine seems well made. Yes they are pricey, but its alot easier and loads of manhours quicker than stripping back a loom. Depending on your wiring abilities its probably 100% better than a bodged up stock loom.
