Old 09-04-2012, 09:26 PM   #1
bartvtecmini
Default homebuilt frame
hi all im building a subframe do everyone use poly mounts or solid mounts to mount the frame to the shell ?
bartvtecmini is offline   Reply With Quote
Old 09-04-2012, 09:40 PM   #2
solid. most frames will bolt directly to the shell rather than to stock mini mounts then to the shell.
Old 12-04-2012, 05:22 PM   #3
pandhandj
pandhandj's Avatar
bart,
any chance of some pics?
Just because there's no destination in sight, doesn't mean the road's not worth travelling.
pandhandj is offline   Reply With Quote
Old 17-04-2012, 07:30 AM   #4
Birdo
Birdo's Avatar
ECU: Spoon P30
I went for solid mounting for my home made frame, seemed to have done the trick for me.
Birdo is offline   Reply With Quote
