Old 13-07-2012, 10:03 AM   #1
daveyjones
Default Toylander
Here's the little ones Toylander which i built three years ago. Its been through quite a bit. Buy the plans off the Toylander site.
http://www.toylander.com/
I used marine ply board and twin motors driving both rear wheels, takes an adult easy.
Its very strong using wood and steel, no plastic even the steering wheel is metal!! Using jigsaw and drill it's surprising what you can acheive.
best bit is you can legally drive it in a park or on the pavement after purchasing the liability insurance.
Dave.
daveyjones is offline   Reply With Quote
Old 13-07-2012, 10:11 AM   #2
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
Fantastic. I want one for me
Old 13-07-2012, 10:14 AM   #3
daveyjones
Buy the plans and get building they really are easy, strong and become a family heirloom.
Old 13-07-2012, 10:25 AM   #4
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
I plan to. Just waiting for baby to arrive, if it's a boy and/or interested in cars then it will most likely happen.
Old 13-07-2012, 11:06 AM   #5
daveyjones
Use marine ply not mdf or moisture resistant mdf its won't last.
Old 13-07-2012, 01:26 PM   #6
I was looking at the Willys jeep one they do and couldn't help wondering if you could modify it to make it into a Moke
Old 13-07-2012, 02:46 PM   #7
Boxer6960
ECU: Stock
I built a moke gocart to play on. Body is made from 3 pieces of steel and folded for construction. Uses a 1hp gas motor, now trying to make a smaller pedal powered one.
daveyjones if you are interested in selling your toylander build manual shoot me an email.
Boxer6960 is offline   Reply With Quote
Old 13-07-2012, 03:47 PM   #8
daveyjones
You have mail
Old 22-07-2012, 01:29 PM   #9
Quadra
Quadra's Avatar
Oh me too, I built one about 5 years ago, great fun, but its for the kids really
Quadra is offline   Reply With Quote
Old 22-07-2012, 03:09 PM   #10
daveyjones
Where id you get the wheels from???? Does it ground out???
Old 23-07-2012, 08:50 AM   #11
Quadra
Quadra's Avatar
The wheels are from a Suzuki LT50 quad bike and we have never had any issues with ground clearance or wheels hitting the arches.
Fun in the snow.
http://youtu.be/61nrjLGHKTE
Old 23-07-2012, 04:50 PM   #12
daveyjones
single or twin wheel drive?? We bought the town & countries and its 24v twin motor, scary as hell when being a passenger due to the driver having no concept of cambers and turning corners at speed!!! Bit of a white knuckle ride to say the least.
Going to progress to build a alfa romeo p3 replica scale using a 200cc engine with centrifugal clutch next . Have the wheels etc just got no time to start it yet..
http://cyclekarts.com/11903Dspd.JPG
Old 23-07-2012, 05:56 PM   #13
Quadra
Quadra's Avatar
Twin wheel direct drive via two 370w 24v motors and disc brakes.
I also made a steering box to reduce the effort required to turn the big fat front tyres.
I know what you mean about being a passenger, but they do get better with age.
Old 23-07-2012, 09:30 PM   #14
daveyjones
Are those cable operated go kart discs?? Like the steering set up,geared to make it a lot easier to turn.Should go well with 370w motors in. We are using 180w's with twin 60 amp batteries running through an upgraded speed controller, Goes well for a couple of days on a charge. Fair play to it its been under two feet of water, hit a van, hit the work unit and is still plodding along.
Not so sure my eldest took me for a spin in my mini and must say a couple of over taking manoeuvres had me thinking I was in a chase set from James Bond and he's 23.
