#1 |
Went back to check altinator like you do !! Boom,boom,
I was less than impressed with what I did while drunk!! So spent last 3 days trying to improve it, embarrassed,ly, So with noticing several altinator bracket fails for unexplainable reasons I'm looking hard at this, I think I'm happy , but just about to add a outer wrap around Strap from the outside of the semi slotted adjust bar to the bottom swivel point , It will run around the front of altinator following its shape, Anyway? I want to make a thin water sheald to simply attach to that Downward bar , Why don't altinator seem to ever be shealded in any way?
#2 |
I have a shield to one side of the alternator to protect it from heat from the exhaust manifold. I wouldn't want to shield it too much as they need air to keep them cool
my build: http://www.16vminiclub.com/forums/showthread.php?t=4887 https://youtu.be/X7O46JmFPh0 |
#3 |
Thanks Garry, so heat is a issue,
I was going to shroud most of it but in veiw of what you say I will think again at just Manifold heat diflextion,
#4 |
stop mucking about , just come racing , you dont need sheild
Mini Restoration on YouTube VW camper in storage , Red hot , www.16vmini.co.uk www.jetblackmini.co.uk Dad's Building K1100 : bmw.16vmini.co.uk , donate to club running costs : paypal@16vminiclub.com |
Thread Tools | |
Display Modes | |
