Old 20-09-2017, 07:12 PM   #526
Purtsi
Purtsi's Avatar
Got some new parts for the turbo conversion =P
So there's a 13 row oil cooler with AN10 connectors. Turbosmart bov and boost gauge. Oil filter sandwich adapter with thermostat attached to Ford motorsport 90deg oil filter adapter.
And hopefully that adapter fits between the engine and frame. There should be just enough space if my calculations are correct
I have a cunning plan...
Old 20-09-2017, 08:06 PM   #527
kcchan
kcchan's Avatar
Are you going to try keep the round nose?
Suck, Squeeze, Bang, Blow.
Old 21-09-2017, 05:01 AM   #528
Purtsi
Purtsi's Avatar
Not trying, keeping it I don't mind if the turbo peeks a bit through the grill tho. Which is actually most likely to happen.
Old 21-09-2017, 02:23 PM   #529
kcchan
kcchan's Avatar
Nice, I'd like to see how you got on.
Old 27-12-2017, 04:40 PM   #530
Purtsi
Purtsi's Avatar
Decided to fit the oil cooler. I made the brackets from a junk stainless steel sheet that I found from the garage. Several hours later the cooler fit like a glove
I relocated the oil pressure hose from the block to the sandwich plate to free up some space for the turbo. As you can see the oil cooler hoses hung quite low, actually those are in the same level as the oil pan. I really would like to get those higher but there just weren't any space in any other angle.
Old 27-12-2017, 07:43 PM   #531
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
Neat job
Old 05-03-2018, 08:26 PM   #532
Purtsi
Purtsi's Avatar
I shedded some weight by changing the battery to a smaller one =P
And I also started making the turbo manifold. it's just somehow tacked together and will require a lot of grinding and welding and grinding before it's done.
Old 07-03-2018, 07:14 AM   #533
cedric998
hmmm, the oil hoses hanging around at such a low level without any protection ??
Old 07-03-2018, 07:37 AM   #534
Purtsi
Purtsi's Avatar
Yeah, I'm fully aware of that. I've got an old sump guard that I've made many years a go. I'll see if it can be modified to fit so that it would cover the hoses. I just haven't had a chance to do it yet.
Old 08-03-2018, 11:33 AM   #535
DVO
DVO's Avatar
ECU: Chipped
When you manage to hit those hoses you got a serious problem and not only with the hoses
Dennis
Old 08-03-2018, 12:32 PM   #536
Purtsi
Purtsi's Avatar
I found a picture from '09 of my sump guard
It's clearly too short to cover the hoses so it'll need some major work to fit.
Dennis: yeah, I'm not too fond of instant oil drain on the road
Old 06-04-2018, 11:38 AM   #537
Purtsi
Purtsi's Avatar
I couldn't get the old sump guard to fit so I rerouted the hoses. Now those are few centimeters higher than before.
Also, I've been working the turbo manifold. Oh man, does that take some work. Parts are just tacked together and already found out that I need to redo and rethink few things as it'll be a tight fit.
Old 07-04-2018, 05:26 AM   #538
Mini Vlatko
Mini Vlatko's Avatar
Will you be leaving Suzuki ITB's for intake?
Old 07-04-2018, 05:42 AM   #539
Marcus Nordblom
ECU: 40mm mikuni rs
Nice work with the intake! 38mm mandrels?
Old 07-04-2018, 01:00 PM   #540
Purtsi
Purtsi's Avatar
Nope, idea is to use standard intake with 45mm TB from MG.
Marcus: yes, if I remember correct
