Old 08-09-2007, 08:30 AM   #31
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
its an af-30 fuel/air meter, gives you a hint wats going on in the engine compartment during set up sweeps
marcus
Old 08-09-2007, 10:19 AM   #32
Andy_S
Andy_S's Avatar
ECU: Megasquirt ... kinda
Clever stuff.
Old 13-09-2007, 08:39 AM   #33
Swiftmini
Send a message via MSN to Swiftmini
Gonna take 2 hrs for me. Problem is i don't have anywhere where i can stay online for that long.
I willl see it soon i hope
These days I have :- s13 200sx driftcar with rb25det + big turbo. Also I have r32 4 door drfitcar with an sr20det and hks turbo kit circa 350-380hp. Also I have a k10 micra with cg13de on twin dcnf webers.Soon to be started rat elf with either 1310cc a series or a cg13 micra lump. Nissan FTMFW :D
Swiftmini is offline   Reply With Quote
Old 13-09-2007, 10:22 AM   #34
Marcus Nordblom
ECU: 40mm mikuni rs
i can put it up on youtube for you mate,
marcus
Old 13-09-2007, 12:15 PM   #35
Swiftmini
please do
Old 13-09-2007, 12:53 PM   #36
Marcus Nordblom
ECU: 40mm mikuni rs
Kev watch this out
marcus
Old 15-09-2007, 10:39 AM   #37
Swiftmini
Cheers matey that was good Certainly makes all the right noises.
Kev
Old 28-09-2007, 04:07 PM   #38
Marcus Nordblom
ECU: 40mm mikuni rs
got some cool stuff, 3,5 kg:s billet fly, adjustable cam gears (modified orig), and a underdrive pulley with trigger wheel.
After fitting the new smaller pulley and some carb tuning she really flies! next job is fit fly, install wild cams and fabricate 4-1 header…
marcus
Shot with Canon DIGITAL IXUS 65 at 2007-09-28
Old 28-09-2007, 10:51 PM   #39
ed4ran
ed4ran's Avatar
I recognize that flywheel
Where did you get that trigger wheel from? (price?)
and can it come in 36-1 form? or only 60-2?
Did you make the cam gears yourself? Good idea
Ed
Old 29-09-2007, 07:15 AM   #40
Marcus Nordblom
ECU: 40mm mikuni rs
it´s from rdv engineering in holland
flywheel about €200
modified cam wheels €100: ish
pulley €125 + €45 for machining a flange and machining/drilling of my 5" trigger wheel (60-2 go for roughly €60)
i sent him cam wheels + trigger wheel
His name is Ruud and i can highly recomend him, he builds race engines and sells adaptronic ecu aswell…
http://www.adaptronic.nl/
//marcus
Old 29-09-2007, 08:58 AM   #41
ed4ran
ed4ran's Avatar
I have just got a flywheel of my own off of him!! (that is why i said i recognized it )
Nice to know he does the trigger wheels etc as well.
Old 29-09-2007, 09:20 AM   #42
Marcus Nordblom
ECU: 40mm mikuni rs
ok! it looks really good to me!
– is it true that 1 kg off the fly is equal with -10kg of the car?
marcus
Old 29-09-2007, 10:15 AM   #43
ed4ran
ed4ran's Avatar
I dont know, but mine is slightly different its not a GTI one.
Mine should be alot lighter than my current one!!
Are you going to pull the crank etc and get it all balanced together?
Old 29-09-2007, 11:45 AM   #44
Marcus Nordblom
ECU: 40mm mikuni rs
no just smack it on there! i believe you will feel if its unbalanced…at 9.000rpm :P
marcus
Old 29-09-2007, 12:16 PM   #45
Hi Ed,
Swift engine is very well balanced as std.
I have them lookded at by my mate who tunes and mod engine for living.
He told me this little engine(G13B) is best balanced he has seen from factory.
He told be all of con-rod and crank are all shot peened as well as balanced.
Spend your money else where he told me!
Atchi
