Old 25-01-2018, 07:33 AM   #1
Felixy69
Default header help b18 + Minitec
hi guys
i am looking for an aftermarket header for b18 motor with minite frame kit
that doesnt require body mods
please help
what did you use ??
thanks
Felixy69 is offline   Reply With Quote
Old 30-01-2018, 08:33 PM   #2
joltfreak
joltfreak's Avatar
ECU: Standard-ish
I found that you will need to trim a bit even using the stock header. T
It is not much and would be hidden be the grille. I have an aftermarket DEI 4-2-1 race header which hugs the block and take as much room as the stock unit
Old 30-01-2018, 08:35 PM   #3
joltfreak
joltfreak's Avatar
ECU: Standard-ish
