Old 17-01-2018, 05:43 AM   #1
Beanman
Default Allspeed Subframe Spacers/Pads Needed?
Upon trial fitting my allspeed subframe into my 1994 rover mini I've run into an issue where the subframe looks slightly misaligned when the tower bolts have been tightened down. By that I mean the lower mounts aren't flush against the firewall (see picture below). The top of the mounting pad makes contact with the lower firewall but the bottom of the pad is lifted. If I were to drill the holes and fasten it like this I think it could warp the firewall..
https://ibb.co/dMwq6m
My question is are "pads" or "spacers" required between the subframe tower and the firewall? (location pointed out in the picture above) I'm thinking they would help with the alignment but it doesn't mention anything of the sort in the allspeed instructions. What has been done out there?
When removing the standard subframe there were "pads" like this:
https://www.minimania.com/part/21A25...Pad-Mount-Mk1v
Im thinking something like the poly ones in the kit here:
https://www.7ent.com/products/solid-...c-str640a.html
Old 17-01-2018, 10:23 AM   #2
monkey
monkey's Avatar
ECU: A box of chips
You should have received solid spacers/washers that go under the tower bolts.
They're shown on page 6 of the manual here
http://www.allspeedengineering.com/d...nual_b16a2.pdf
Old 17-01-2018, 01:09 PM   #3
Doodling
I asked this as well,
no the is no need for a spacer between the bulkhead and top of the tower.
Any questions give allspeed a ring and they’ll happily answer them.
Doodling is offline   Reply With Quote
Old 17-01-2018, 02:19 PM   #4
I can't work out what you meen ? Well I do know but don't understand?
Old 17-01-2018, 02:51 PM   #5
Beanman
Yes I'm using those! I'm just concerned about the other side where the tower bolt inserts into the subframe (where the tower meets the firewall). Just because the stock mini subframe uses a spacer.
Old 17-01-2018, 03:01 PM   #6
Beanman
Right! Thanks for the info. I will give them a ring when I'm back home because I'm curious if you can run bushings there to help with vibrations. And I'm still thinking it will help align those bottom pads, were your lower mounts perfectly flush with the firewall?
Last edited by Beanman; 17-01-2018 at 03:09 PM. Reason: Added Pictures to first post
Old 17-01-2018, 04:22 PM   #7
No two Minis are exactly the same, the factory jigs ended up with 40 years worth of wear so the tolerances on later shells can be eye wateringly large. I suspect it will all pull up tight when you bolt it all down.
Old 18-01-2018, 02:31 PM   #8
Beanman
Right that does make sense. To sum things up here is what Rob from Allspeed told me:
"The Allspeed subframe is intended to be solid mounted, you just require the supplied large washer under the bolt head, nothing between the tower and bulkhead x member."
Old 19-01-2018, 11:47 AM   #9
monkey
monkey's Avatar
ECU: A box of chips
Yup as Oz said, I had this with a past build I did. The frame fitted once it was bolted up fine.
Solid mounted too, so I'd make sure you have the extra metal welded in as per manual where to bottom bolts up.
Tags
allspeed, pad, spacer, subframe
