Old 09-11-2017, 07:56 PM   #1
Default B series Inlet to clear bulkhead
http://magnusmotorsports.com/product...d-mini-cooper/
a guy on FB Honda Powered Mini page posted this link, it appears that those with deep pockets can now buy a purpose built inlet for a B series that clears the bulkhead on a Mini
Old 09-11-2017, 08:12 PM   #2
Yum yum
Old 10-11-2017, 09:27 AM   #3
monkey
monkey's Avatar
ECU: A box of chips
Looks really good....until I saw the price
Edit - Also there is no confirmation what frame this has been fabricated on, I doubt it'll be Allspeed.
Old 10-11-2017, 12:07 PM   #4
I would expect it'll be for the Minitec frame but my understanding is that they mount the engine further back than Allspeed do (hence why the standard exhaust manifold fits) because it's designed around LHD so there is no clash of diff against Steering rack the RHD conversions suffer (and hence the Minitec RHD conversion panels that have to move the rack back).
If that's the case then it should give clearance on an Allspeed frame but who's the first to spend the best part of a grand (before taxes) to give it a try ???
Old 10-11-2017, 06:27 PM   #5
monkey
monkey's Avatar
ECU: A box of chips
I thought it’d be based on a minitec frame too. It’ll be interesting to see if superfastminis/minitec start stocking this soon.
I think price wise it’s clear that it’d be much cheaper to cut and weld a standard inlet manifold like some have done in the past. Although still costly I guess
It would be interesting to see the performance gains with running that inlet manifold though.
Old 11-11-2017, 12:47 AM   #6
joltfreak
joltfreak's Avatar
ECU: Standard-ish
I had paid local shop to cut and weld up my skunk2 intake.
It cost me less than $500 (including the new intake)
Old 15-01-2018, 02:40 PM   #7
VT-Doo
VT-Doo's Avatar
CC: 1797
ECU: Hondata S300
I'll just use ITB thanks
Ian
VT-Doo is offline   Reply With Quote
