Old 24-07-2017, 08:01 PM   #1
Rob Evans
Rob Evans's Avatar
Default The Story So Far,,,
Thought I'd do a recent progress report
Unfortionatly my original build diary somehow got deleted a while ago
With the engine and gearbox now rebuilt I decided to fabricate an exhaust manifold from stainless 304.
Atchi came to the rescue with the stainless exhaust and inlet flanges, the rest came from good old eBay.
For the the 4 headers I used 1 1/2" then into 1 3/4" and tigged em up
Then put the bottom 1 3/4 bend in.
Next I needed to do the middle two headers... Took quite a lot of thinking and working out.
Fitting it up, all the joins now tigged together, I purged the inside with argon to get a clean strong weld.
With the down pipes done a 1 3/4 Y piece was constructed.
Cleaned up with pickling paste... Nasty stuff!
Welding the manifold flange up.
Trimmed up and Y piece welded on.
Rob Evans is offline   Reply With Quote
Old 24-07-2017, 09:17 PM   #2
andyfkettle
andyfkettle's Avatar
Nice work. Do you have a link to the pipes off eBay?
Old 25-07-2017, 04:51 PM   #3
Rob Evans
Rob Evans's Avatar
Hi Andy - There's quite a few suppliers of stainless tubing on eBay, typically...
http://www.ebay.co.uk/itm/1-5-90-DEG...MAAOSwxg5X0CO4
I used 1 1/2" 38mm straight, 45 deg and 90 deg bend and also 1 3/4 straight and 90 deg bend.
Old 25-07-2017, 05:55 PM   #4
andyfkettle
Ok ta for the info just nice to find and use quality stuff and yours looks good.
Old 25-07-2017, 06:41 PM   #5
andyfkettle
Old 31-07-2017, 09:13 PM   #6
Looks good!
Old 10-11-2017, 10:44 AM   #7
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
Yea top job unbelievable clean engine, soda blasted?
Old 26-11-2017, 08:51 PM   #8
Rob Evans
Rob Evans's Avatar
Sand blasted and then sprayed with Silver King paint from Autosmart.
Had really good long lasting results on ally castings with this
Old 08-12-2017, 04:44 PM   #9
Marcus Nordblom
ECU: 40mm mikuni rs
Looks great
Old 09-12-2017, 10:25 PM   #10
joakwin
CC: 1.6
ECU: Bone stock
sweet
Old 25-03-2018, 06:54 PM   #11
Dave Potter
Dave Potter's Avatar
Great to see the progress picture up Rob, really is a nice job
Dave Potter is offline   Reply With Quote
