Old 30-09-2014, 01:14 PM   #16
I have seen thanks,
Old 01-10-2014, 08:59 PM   #17
kees2501
kees2501's Avatar
ECU: no ecu!
little progress here.
-cleaned the yamaha r1 carb.
-got the dxf files of inlet and outlet flange to the lasercutter. thanks to miniswift.
-created a new water pulley. just for the demensions so it fits in the frame a bit better now. the pulley needs to be made more secure to get it balanced.
rest of the time last weekend i spent on my other car.
kees2501 is offline   Reply With Quote
Old 05-10-2014, 05:25 PM   #18
DVO
DVO's Avatar
ECU: Chipped
Why a different pulley for the waterpump? The engine too far to the back?
Dennis
Old 05-10-2014, 06:30 PM   #19
kees2501
kees2501's Avatar
ECU: no ecu!
the pulley almost hits the rubber spring cone. so i think it's better to take a smaller one.
Old 05-10-2014, 07:01 PM   #20
sebastiaan.keijzer
ECU: KMS
Other option is to take some rubber off the cone. More people have done that just to give it some milimeters clearance
sebastiaan.keijzer is offline   Reply With Quote
Old 06-10-2014, 10:34 AM   #21
Alex1380
ECU: Megasquirts
I had the same problem. I went OTT and fitted an electric water pump which i've got to say really helps with the cooling.
Old 06-10-2014, 01:54 PM   #22
kees2501
kees2501's Avatar
ECU: no ecu!
i think that's a good option.
what kind off pump do you use?
l/hr?
bar?
Old 08-10-2014, 08:45 AM   #23
Alex1380
ECU: Megasquirts
I used the Davies Craig EWP80 with the controller.
https://www.merlinmotorsport.co.uk/p...r-kit-ewp80kit
Max flow is 80L/m but the controller vias the speed to suit the engine temp. You remove the thermostat and the pump sorts the rest. It defiantly helps with warm up and along with a MPI rad and some motorbike fans it keeps it cool.
Old 08-10-2014, 10:02 AM   #24
kees2501
kees2501's Avatar
ECU: no ecu!
does this pump also work without the controller? or does it cool it the engine too much then?
Old 08-10-2014, 11:05 AM   #25
Alex1380
ECU: Megasquirts
You need the controller unless its some form of drag car. If not you need something to switch it on and off. I wouldn't recommend the pump without the controller.
Old 08-10-2014, 02:38 PM   #26
sebastiaan.keijzer
ECU: KMS
Kees,
I read a lot of issues with the ewp80 kit. I dont say its a bad kit or something! More people have a electric water pump ans a lot of modern cars have it too so it would be fine at the end.
Ive got a 2 core radiator and did not ever had any problems with the coolong. I think its a lot of money for something you dont need.
Cheers Sebas
Old 11-10-2014, 04:59 PM   #27
kees2501
kees2501's Avatar
ECU: no ecu!
i'm not gonna use an electric pump i think.
i will get it working with a smaller pulley
today i added my dynamo.
and got this to a metal worker:
Old 05-12-2014, 10:54 AM   #28
kees2501
kees2501's Avatar
ECU: no ecu!
little progress here. almost ready to put the r1 carbs on.
only finish work a flanged edge or how is it called in english.
to hold the carbs.
Old 15-12-2014, 09:11 AM   #29
kees2501
kees2501's Avatar
ECU: no ecu!
and it looks like it al fits!
Old 15-01-2015, 08:23 AM   #30
kees2501
kees2501's Avatar
ECU: no ecu!
intake is a bit longer than i hoped. but is fits without cutting anything from the mini.
