Old 29-03-2014, 09:12 PM   #16
DVO
DVO's Avatar
ECU: Chipped
Some more progress: welded up under te right rear window, inner sill and under the bootlid. After that we can start straightening the car with filler. But first to the more fun part: the mechanics .
Dennis
Old 30-03-2014, 10:44 AM   #17
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
Good to see this getting fixed rather than scrapped. Unfortunately Beritone filed for bankruptcy this week.
Old 31-03-2014, 12:39 PM   #18
DVO
DVO's Avatar
ECU: Chipped
When I see what is fixed on here this is an easy project. Sentiment also got a bit in the way too
Dennis
Old 21-04-2014, 01:39 PM   #19
DVO
DVO's Avatar
ECU: Chipped
In the last few weeks more welding done. The better you look the more comes up. But you have to end it somewhere.
I always took into account that every year some welding would be needed. The most important things have been done now. Only the doors need sone work, but that can be done at a later time.
Dennis
Old 03-06-2016, 09:28 AM   #20
DVO
DVO's Avatar
ECU: Chipped
Two year further and not much progress. In these past years bought some other doors and a brand new right hand front wing, but for the rest it is just standing there. Good thing is that my other project is on the road again and needs a bit less attention. Maybe next winter....maybe. Still love the little car though.
Dennis
Old 18-03-2017, 03:19 PM   #21
DVO
DVO's Avatar
ECU: Chipped
Still not much progress after my last post, but I still did not abandon the project. I got hold of a 4WD project based on a Subaru Justy. It was started by Sebastiaan over here, but stopped because he moved on to another project.
Idea is to fit this in the Innocenti in the end. The front subframe is more or less finished. On the rear he started out with using suspension arms of a BMW E30. My idea is to use a front subframe in the back like the GTM does and hang the diff in between. This is easier and cheaper to accomplish and allows me to keep the rubber suspension.
Below some pictures (thanks to Sebastiaan).
Dennis
Old 24-09-2017, 10:51 AM   #22
DVO
DVO's Avatar
ECU: Chipped
Decided to put the Mini on sale and continue with this project when it is sold. It turns out that I am more of a builder than a driver.
That is why I took the time to put all the pictures back in this topic after Photobucket screwed up. Luckily there weren't that many pictures . I am now using IMGBB by the way.
At the moment I am collecting all the parts to start building the rear subframe. Calipers, discs, etc. To be continued.
Dennis
Old 12-10-2017, 02:09 PM   #23
Phaeton
Phaeton's Avatar
Too late for me as I've removed all my photos from PB but install this chrome extension & anybody who not removed them their images will be visible https://chrome.google.com/webstore/d...cpkaon/related just tested it on Chrome & Ubuntu & it works
Old 27-12-2017, 08:51 PM   #24
DVO
DVO's Avatar
ECU: Chipped
Started work on the rear subframe. I got myself a front subframe and started measuring, more measuring and then some cutting. After two afternoons of work the result is as below. First picture was roughly lining things up. The next pictures how it ended up. Frame still needs some extra bracing but I am happy with the result. It ain't beautiful but it is functional.
Dennis
Old 28-12-2017, 08:42 AM   #25
cedric998
it does not look really bad
brgds
chris
Old 28-12-2017, 01:43 PM   #26
Hi,
Do you know how to make a front subframe to work in the back for hand brakes?
I have a drawing of what you need to do if you need help, let me know.
Do you have drum brake front hubs, CVs?
Good to see you are doing this car up. I wanted one but you can't find one in UK.
Atchi
Old 28-12-2017, 03:58 PM   #27
DVO
DVO's Avatar
ECU: Chipped
I tried to fit MGF rear brakes, but that did not work out really. Stopped messing around and bought myself some Ford Fiesta calipers. Together with a hydraulic handbrake this will be enough to get it through Dutch MOT (APK).
Curious how your set up looks Atchi, I have complete set of drumbrake calipers and shaft lieing around.
Dennis
Innocenti's are getting rare anywhere in Europe, especially the Mini based ones.
Old 28-12-2017, 05:16 PM   #28
Phaeton
Phaeton's Avatar
If using Mini hubs with a small amount of machining you can get Golf MK2 rear calipers to fit/work
