Old 01-01-2018, 08:03 PM   #2461
No problem, worthwhile having a set cleaned and putting them on
Old 01-01-2018, 08:13 PM   #2462
will16
will16's Avatar
ECU: K Maps 170
Originally Posted by gadget555 View Post
Is it worth swapping to the cream injectors from the blue ones?
I maybe wrong, but if your ecu's been remapped, swapping out the injectors would cause it to run richer? When I converted mems2 143 to mems3 k maps I had to swap mine
Old 01-01-2018, 08:21 PM   #2463
Ah now there's a conundrum as I have both a standard 160 ECU and a Kmaps race ecu which to use with what?
Old 01-01-2018, 08:46 PM   #2464
A call to Kmaps will confirm, but the Kmaps ECU will probably run in open loop upto a curtain RPM and compensate for the higher cc injectors, it will probably run a little rich at higher revs, youíll need to drive the car a while though so the ECU can learn to compensate for the change in injectors.
Old 02-01-2018, 10:18 AM   #2465
I have spoke to K-maps and have been told that both ECU's I have have been mapped for the blue injectors so to stick with the ones that are in it.
Old 02-01-2018, 10:22 AM   #2466
Fair enough, I think they should consider telling people to move over to the cream ones and map to suit those as an option when people are buying a re-map as the blues will be maxed out after a re-map.
Old 11-01-2018, 07:31 PM   #2467
How about this bling column for your garage queen?
Bling steering coloum by Keith Thornburn, on Flickr
Bling Ssteering coloum 1 by Keith Thornburn, on Flickr
From Billet Works Australia!
Old 11-01-2018, 07:49 PM   #2468
Thatís actually very nice, but I donít think itís very Henry and Iím supposed to be curbing the spending
Old 11-01-2018, 08:10 PM   #2469
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
It's not made out of unibtanium either.
Old 11-01-2018, 08:41 PM   #2470
Gay.
Yes Dan is a man of leisure from next month.
Old 11-01-2018, 09:04 PM   #2471
Gay.
Full time mum, gonna change my profile and pic on Facebook to suit too, little duckface and cleavage should suffice
Old 11-01-2018, 09:17 PM   #2472
I was running blue injectors with that ecu
Chris16v is online now   Reply With Quote
Old 11-01-2018, 09:31 PM   #2473
Cheers Chris.
Old 11-01-2018, 10:47 PM   #2474
CooperWorks
CooperWorks's Avatar
ECU: Mems 3
Talking
Old 12-01-2018, 12:06 PM   #2475
Dan, How did you find setting the cam timing with the verniers?
I will need to do the same but if i'm honest it baffles me!
