Old 25-10-2014, 09:48 PM   #1786
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
what are the original injectors for the ecu? high or low impedance? if the original ones for that ecu are low you will need resistors...also, if they are different than stock and the correct resistance you need to change the dead times in the map or it will run like doodoo.
Old 25-10-2014, 11:25 PM   #1787
The original injectors are high impedance too, I've put those back in to cancel out the bigger injectors as bring the problem.
Been having a poke around this afternoon, checking earth's and everything, starts with a squirt of easy start!
Ordered a Power Probe 3 and I'm going to go through the plug and play loom, that's the only other possible thing I can think of after Emerald telling me the ECU is fine.
Old 26-10-2014, 07:12 AM   #1788
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
just be really careful with the power probe tester. If you stick power down the wrong circuit your ECU will be toast Nice bit of kit though, you can lend it to me next year, even better now your within driving distance
Paul
Old 26-10-2014, 08:41 AM   #1789
I'm going to disconnect it from both ends and put power down each pin with my volt meter at the other end.
My mate Andy had one when I was in Surrey and it was ideal for fault finding and testing.
Your welcome to borrow it anytime.
Old 26-10-2014, 08:49 AM   #1790
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
You can check continuity with a multimeter. Dead easy.
Old 26-10-2014, 09:10 AM   #1791
Not mine, I've got some automatic thing that's a pain in the ass.
http://buy1.snapon.com/catalog/item....roup_ID=675530
Old 26-10-2014, 10:06 AM   #1792
raider16v
raider16v's Avatar
ECU: s300
Wilson may be on to something with the dead times? I had to change mine when I went from RC550cc to ID1000cc Just a thought!!!
Hope you get it sorted
Take it easy
Mark.
b16a turbo clubman build
raider16v is offline   Reply With Quote
Old 26-10-2014, 10:41 PM   #1793
speedy
speedy's Avatar
ECU: standard,for now
is the earth okay?
if the injectors are switched negative, or are they positive switched?
new engine is done...
Old 27-10-2014, 05:46 AM   #1794
Earth is fine, double checked it already.
Injectors are switched negative, I have 12v at the injectors but until my noid light arrives I can't check for the switched earth.
Old 02-11-2014, 01:05 PM   #1795
Making a bit of progress, I'm using my old MEMS and the cream injectors for testing as i get a signal from the MEMS for testing.
Noid light on 4 is bright and by the time I get down to 1, I get nothing, 3 and 2 get progressively worse.
Thinking it's my injector loom at fault
Old 02-11-2014, 03:13 PM   #1796
minidarren83
minidarren83's Avatar
Have you power tested the loom yet? Also have you had a light on the output of the k6 ecu for the injectors? If so does it flash when the engine is cranked test all four directly at the ecu output you could try read the voltage but I'm assuming it will be difficult to get a reading with it constantly flicking on off unless you have a tester that record peak voltage/amps ect. If you get a reading you are expecting from the ecu signal output when cranking then it can only be a disconnect between the ecu and injectors. You could also power test your earth circuit if you know what your doing. Sorry if you have done all of this just thought if throw in my bit
minidarren83 is offline   Reply With Quote
Old 02-11-2014, 03:15 PM   #1797
minidarren83
Also what did the injectors come from is there a possibility the are looking for a different voltage that the k6 and mems is giving out?
Old 02-11-2014, 03:56 PM   #1798
I haven't bothered testing the K6 for injectors as it's been back to Emerald and come back with a clean bill of health.
The injectors work on a switched earth signal that I can't easily measure without an oscilloscope, I'm currently using the Rover cream injectors I was running on before until I get it running again and trying the SAAB injectors again.
I assumed the SAAB injectors killed the drivers in my K6, but Emerald tell me it shouldn't have any problems running 12ohms and tested this whilst they had the ECU back.
The K6 must work differently though if the problem is with the injector loom as I get absolutely nothing on the noid light with the K6 and I'm obviously getting some strange results with the MEMS.
I do have to power test the plug and play loom still, if that's fine then its I'll change the injector loom, shame I haven't got a spare, would've taken seconds to switch over!
Old 02-11-2014, 04:53 PM   #1799
minidarren83
I wouldn't be surprised if when they had the k6 back they fixed something and maybe upgraded the drivers to save face and reputation. I have read somewhere that the k series did suffer from engine bay wiring issues is there no way you could get the noid plugged directly to the ecu output pins to rule out the loom and also verify the k6 does work. Also have you disconnected the inj loom and put power down it or even a continuity test
Old 02-11-2014, 04:55 PM   #1800
I have a spare injector loom off a 143 mems 1.9 If you would like to try it I'll put it in the post, It's the one with the small yellow connector with 5 pins in it.
gadget.
gadget555 is online now   Reply With Quote
