Old 22-08-2012, 06:16 PM   #31
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
good skills
Old 04-11-2012, 07:36 AM   #32
meeni62
meeni62's Avatar
ECU: carbs
Guess I should update this!
I've been really busy with motor racing lately as I've finally secured a drive again for the remainder of this year and next year in the v8 utes which has taken up a lot of my time of late but this weekend is a long weekend so I've done a little bit of work!
Purchased a lot of parts lately including minisport 7.9" 4 pot brakes
Spek pro gauges (as used in NASCAR with lots of cool features)
Protech coil overs
3tech cams
And a few other bits and pieces!
Today I fabricated a clutch slave mount which after coming up with several extravagant options, found a way of doing it in the most simple way while being strong! It's basically a peice of angle bolted to the gearbox casing then welded to some round bar which has been drilled and tapped to suit the rose joint with a small tab welded on which connects to whatever that box is on top of the gearbox (technical) which makes it super rigid! I then just welded some angle onto the original clutch arm and drilled a few holes for adjustment!
Looks too close to the box there but it's not..
I also sat the suspension and brakes in
And re fitted the engine, with the master cylinder reservoirs etc in to check for space
Will get the engineer to come and have a look at my work before I throw it all into the real car!
Can't wait!
Sean
meeni62 is offline   Reply With Quote
Old 08-01-2013, 11:06 AM   #33
meeni62
meeni62's Avatar
ECU: carbs
Havnt updated this in a while!
Engineer told me to go ahead and build the car up, so I did, il let the pictures do the talking but I'm about 80% there with the dry build before i take it apart and paint everything and build it for real!
Too many things done to comment on! Enjoy!
Sean
Old 08-01-2013, 12:02 PM   #34
Kaison
Kaison's Avatar
Looking great
I only bow under braking.
Old 10-01-2013, 01:14 AM   #35
this is verry smoth,, the mamba wheels are so light its unreal.. the engine seems to be the best for cc,s in the world[mini fit] but please plug your carb opening,, makes me feel uncomfatable like a hungry crockodile wateing to swallow..
Old 10-01-2013, 09:27 PM   #36
meeni62
meeni62's Avatar
ECU: carbs
It will have filters don't worry..
Cheers guys
Old 11-01-2013, 10:02 AM   #37
meeni62
meeni62's Avatar
ECU: carbs
Made an extension panel for my current dash today out of aluminium, still needs a speedo
It's a two piece thing so the face plate will be painted (properly not just with a can like in the photo) and I upholstered the outside part in the same vinyl as the dash.
Getting rid of the old Sony speakers to put something in which matches the rest of the system I have..
I also had the postman deliver a new pipe flaring tool to me today, I originally bought one of those normal style cheap ones which made bananase looking flares, this one is awesome!
Here's my first attempt..
Much better then the pineapple before I can assure you!
Sean
Old 11-01-2013, 10:39 AM   #38
Cheers guys
this is gunna be a beast!! i have verry similar brakes to yours so i can run 10" wheels. im sure they will be ok while new but not sure when they wear out a bit. then also when i use my 13" wheels i think they take more stoping with that bigger rolling radious. anyway my coment about the open air holes is down to a fear of mine,, i dont care about a filter on the road funny enuff ive never had any major problems from that,,
it was down to a bad lesson when i was lerning, i was working on a alfa g.t.v 2.0 and had the airbox off i was happly reving it and 1 of the 3/8 th nut from the airbox got sucked in, cant say anymore about that but its given me a paranoid feeling when any engine orofice is open to nuts e,c,t.
and yours are looking just ready for something to fall in,,
im sure its o,k just me,, nice work there.
Old 13-01-2013, 09:04 PM   #39
KMG
CC: 1293
I like your dash design,I was trying for something like it but it did not end up as nice as I hoped.
Old 13-01-2013, 10:53 PM   #40
meeni62
meeni62's Avatar
ECU: carbs
Thanks, it isn't hard to make, cut a strip of aluminium and fold it around into the desired shape, weld it together. Weld the mounting tabs onto it, then sit it on some aluminium sheet and mark around it, cut the shape out, that's your face plate done.. I put nutcerts on the tabs and then mounted it with m6 Allen bolts.. Took me half a day to make
Old 17-10-2014, 10:22 AM   #41
meeni62
meeni62's Avatar
ECU: carbs
Geese, much has changed since my last update (I've been logged in with a different name wondering why I can't post... Now I know)
Without going into too much detail the car is 80% finished but I'm doing a commercial pilots license so funding is hard to come by.
I've changed (since last update) the dash, cut the front off so it's removable and switched to fuel injection with throttle bodies.
I've painted the engine bay and frame and started putting it all back together, run lines etc. painted the boot and fitted the fuel system but I'm waiting on parts to finish that.. Here's some pics
Painted frame
Exhaust
Put the pg LSD I had in the gearbox
Engine bay with lines and frame installed
Boot
Engine in with spaghetti everywhere
Stainless fuel lines with billet mounts
Brake lines are also billet mounted
Triumph tt600 itbs which I like because they're easily spaced and don't have injector holes
Dash setup (need to cover the brake lines)
Little things like custom painting the gear knob
Guess that's up to date now.. Any questions? Lol.. Il try and update as I do things from now on
Sean
Old 24-02-2018, 06:28 AM   #42
Barney
Hi meeni62
Just about to put a gb13 into a clubman , can I annoy re pics etc
I DO NOT have photo bucket , but a could give mail address , I'm in Epping Melbourne
Barney is offline   Reply With Quote
Old 24-02-2018, 02:13 PM   #43
99fusion
there's a chrome and maybe firefox plugin to get around this, have a look in non 16v section of the forum first maybe
Old 15-05-2018, 09:34 PM   #44
Barney
Hi mate
Where in Victoria are u
