Old 19-03-2012, 08:13 AM   #31
DVO
DVO's Avatar
ECU: Chipped
Always nice when things come together quickly and were more easy than expected. With my turbo conversion it is a different story
Dennis
Old 22-03-2012, 08:11 PM   #32
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
I love wiring, in fact the only thing i love more than wiring is inserting a hot needle in my eye
Here is what i started with
I spent yesterday going through the loom and tracing all the wires to the ECU to find out what they did and labeled them all up.
Today i took a brave pill and stripped out the wires i don't need which is pretty much everything
Here is what i ended up with
We had to buy a new radiator yesterday after the old one leaked but it was quite old. I fitted that today.
The alternator belt i ordered turned up today so i fitted that as well.
Having a few days off now while we go to Cornwall tomorrow for a few days in the van
Paul
Old 22-03-2012, 08:33 PM   #33
Andy_S
Andy_S's Avatar
ECU: Megasquirt ... kinda
Look at you Mr Wiring Guru !!!!!!!
Old 22-03-2012, 09:32 PM   #34
PaulW
PaulW's Avatar
Nah Steve came round this morning and set me going
Paul
Old 22-03-2012, 10:01 PM   #35
kcchan
kcchan's Avatar
Got to be nearly there hasn't it?
Suck, Squeeze, Bang, Blow.
Old 28-03-2012, 08:35 PM   #36
PaulW
PaulW's Avatar
arghhhhhhhhhh fookin wiring
Old 28-03-2012, 08:41 PM   #37
Please don't make it out to be a pineapplepy job, hoping to start with my loom this weekend, I'mplanning on using the whole Swift loom for the everything and completely doing away with the Mini loom.
Old 28-03-2012, 08:44 PM   #38
There you go!
I'm just like you I lost will to move on as I'm at wiring stage for a last year.
I have lost my mojo for a bit...
I will start on my wiring soon when I can spend more than 20-30 in 1 go.
Atchi
Old 28-03-2012, 09:20 PM   #39
PaulW
PaulW's Avatar
Please don't make it out to be a pineapplepy job, hoping to start with my loom this weekend, I'm planning on using the whole Swift loom for the everything and completely doing away with the Mini loom.
No mate its a lovely job honest
Originally Posted by ATCHI
There you go!
Nope i haven't lost any enthusiasm its just frustrating and i'm sure its something and nothing
Paul
Old 28-03-2012, 09:38 PM   #40
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
Looking good Paul, glad you seen the light
btw i have 2 complete suzuki harnesses, maybe i can send them to you for some custom work need one mini and one midget
on a serious note is it hard to strip off the ecu bits and just use the fuse box, basic lights etc harness?
or is it better to shell out some hard earned on a custom harness?
keep it up
Old 28-03-2012, 10:17 PM   #41
PaulW
PaulW's Avatar
keep it up
Your 2 questions are connected Marcus
1. i might need one of your looms
IF
2. Ive made a bollox of stripping out all the redundant wires
I'm still keeping the mini loom for lights and hope to just end up with a Suzuki ignition loom. There is just so many wires that share either power or ground and are piggybacked A but further into the loom. I'm after a neat install and it would of been easier to try and hide the complete loom but there is just so much of it.
My problem at the moment is that the engine will turn over no problem. The fuel pump relay is working on the ignition and primes as it should. There is power at the coil but that's where it stops.
I think there is a problem with the wiring from the coil, coil ignitor and noise suppressor and getting this signal back into and out of the ECU to the distributor. The distributor is not doing what its told as i don't get a spark.
A custom harness would be a luxury but not one i can afford. I am going to get another set of ignition leads, dizzy cap and rotor arm tomorrow and at least i can rule all of that out.
Out of interest does anyone know what the resistance should be across the coil when testing it?
Paul
Old 29-03-2012, 05:18 AM   #42
spNOam
spNOam's Avatar
ECU: Tweaked DTA
I used the suzuki loom, stripped of everything not needed and modded to fit the mini - took me a month evenings and weekends, keep it up
To insanity & beyond!!
Geoff
Old 29-03-2012, 06:25 AM   #43
PaulW
PaulW's Avatar
cheers Geoff I'll get there
Old 29-03-2012, 04:10 PM   #44
Marcus Nordblom
ECU: 40mm mikuni rs
one month! if you do it in one month it would take me a year i better get a cheap hotrod loom
Old 30-03-2012, 11:01 AM   #45
I have a service manual with the wiring diagrams if its any help?
