Old 28-02-2013, 07:44 PM   #376
Andy_S
Andy_S's Avatar
ECU: Megasquirt ... kinda
Have you tried a big ass battery? A big amp battery might make up the brief shortfall which you suffer when the alternator drops the ball.
Gotta agree with Mr Ardon to an extent too ..... yikes ..... ensure that your fan is relayed to pull its juice from a big wire running back to the battery. If it doesnt then stick one in cos the fan might be draining the dylithiam crystals so you can't get full warp drive.
Old 28-02-2013, 08:27 PM   #377
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
Originally Posted by miniswift View Post
Hi Paul,
These are the bad boys you need to reduce rpm and make your 1st usable.
I will try to get you a set.
They have 72:19 teeth.
Atchi
Atchi you big tease
What about a proper 5th gear as well?
Paul
Old 28-02-2013, 08:34 PM   #378
PaulW
PaulW's Avatar
hang on ive just been speaking to you on the phone? Were you multi tasking?
Ok i will do as Shaun suggests Just don't tell him or I'll never here the last of it. I'm only doing it as its cheap
I'm still not convinced there is anything wrong with my alternator.
Paul
Old 28-02-2013, 09:54 PM   #379
Paul,
These bad boys will make your car use all of the gears.
I bet you don't need to use 1st gear to pull of at the moment. Your 5th is like 4th in std mini.
If you were using mk1 gearbox, I could get hold of 3.78:1 easily. Let me ask my mate who has mk1 and may be I can get spare so Alan might want to take mk1 instead of mk2!
Atchi
Old 28-02-2013, 11:12 PM   #380
bobjonah
bobjonah's Avatar
At the risk of hijacking your thread - I am still looking for a set of 3.52:1's If you happen across a set please let me know.
BTW I also agree with Ardonfast - get your power source closer to the battery.
Bob Jonah
Old 21-07-2014, 05:44 PM   #381
PaulW
PaulW's Avatar
well after a long stand in the garage........Chester not me He passed MOT today, we insured him.......(being old id great sometimes) and taxed so he's back on the road= happy missus
Paul
