Old 01-03-2011, 08:55 PM   #16
Miniintegra
Miniintegra's Avatar
CC: B18c6
ECU: standard honda
http://www.16vminiclub.com/forums/al...&pictureid=512
Check this one out, total cost 0, might not look good, "but ya don't look at the mantel piece when ya poking the fire" and I am prepared to be disappointed if it's not the best at performance, but god loves a try-er, and if it doesn't work then I ain't lost owt, will just have to invest
Miniintegra is offline   Reply With Quote
Old 02-03-2011, 03:20 AM   #17
Kaison
Kaison's Avatar
550 - 600 isn't too crazy in the manifold area for these engines, you can easily spend 1000 for a decent manifold for the B16B
Old 02-03-2011, 11:14 PM   #18
Kam
Kam's Avatar
Problem is Miniitegra that I could chop up any 4-2-1 ebay jobbie and after much faffle putting it together get some awesome welds on it and use it, but regardless of how it looks I will never know if it ran as efficiently as it should? I could have power loss and wouldn't know where to point the finger at? engine, exhaust, other?
With this one at least I know its the dogs nuts in not just looks but actually performing as I've used it on the rolling road, road and track
I spent 3000 buying my mini, others have spent 300, I spent over a grand just buying the DTA setup, others have spent nowt and chopped up the honda wiring loom, all comes down to the individual and what they can do, fair play to you for making an exhaust manifold but I can't
This just gives people using an allspeed frame a heads up if they are well and truly stuck on the manny side of things, it was just to let people know the old shop manifold is still available thats all
Also it might help someone out like it helped me, I could of kept it to myself and carried on but I'm not like that, I'm not a selfish c**t I like to help out where I can
Old 03-03-2011, 09:20 PM   #19
Miniintegra
CC: B18c6
ECU: standard honda
All credit to you for finding it kam, I thought it was lost when Matt shut up shop! It is a lovely piece of kit, I suspect I will buy it or Xmas pressie eventually! I know where your coming from spending wise, you av to av deep pockets building one ov these things, my 7k has gone no where!!
Old 03-03-2011, 10:06 PM   #20
Kam
Kam's Avatar
Problem is life would be alot simplier (and fuggin cheaper) if I hadn't of found it and just used the standard honda manny with a clubman front.....
can of worms + open = more problems!
I blame Matt
Old 02-07-2012, 09:19 PM   #21
dakin
dakin's Avatar
thank you for your mp Kam, but anybody find a manifold not "custom" who's fine with a standard round nose??
dakin is offline   Reply With Quote
Old 02-07-2012, 09:28 PM   #22
Aidstap
Aidstap's Avatar
It depends on what frame you use mine uses the the minitec frame and the standard Honda manifold fits under a standard length round nose
Aidstap is offline   Reply With Quote
Old 10-07-2012, 10:54 PM   #23
Rick.spi
CC: 1600cc
ECU: None at the moment.
Loving the stainless manifold.
Rick.spi is offline   Reply With Quote
Old 26-11-2012, 07:02 PM   #24
Blonda
CC: 1.6
ECU: PGM-FI OBD-1
Have not got round to my manifold yet but surely it cant be out by much is it? How much does it foul the allspeed frame by?
Blonda is offline   Reply With Quote
Old 29-11-2012, 10:36 AM   #25
Kam
Kam's Avatar
If your making it yourself then you got no issues
If your not and are putting it in a standard roundnose then put the engine in and front bar on and let us all know
Old 30-11-2012, 01:14 AM   #26
Kam
Kam's Avatar
Heres one I made earlier
Manifold is just touching the front bar with the engine position 99.9% done, at 100% done I gave myself another 1-2mm clearance
For peace of mind I cut out and welded in a notch on the front bar for peace of mind to help with engine positioning
Its not needed, it was just peace of mind for me, just remember your engine rocks back on acceleration (inlet goes down exhaust manifold comes up) so you will hear it bang on hard changes with it sitting too tight
And thats with a manifold which sticks out 95mm maximum at the furthest depth, which is about 3 3/4 inch, don't sound like alot but trust me - thats some serious hugging of the block
Old 10-02-2013, 08:47 PM   #27
miccoli
miccoli's Avatar
ECU: STANDARD
I'm interested the manifold .... kam where you bought it?
miccoli is offline   Reply With Quote
Old 11-02-2013, 01:50 PM   #28
Kam
Kam's Avatar
Did you not get my PM? The link for the company (Hayward and Scott) is in the first post, but they don't have the manifold on there website as its custom made, they have a jig there for it so send them an email and ask them for postage etc and ask for Ian
Old 11-02-2013, 02:13 PM   #29
miccoli
miccoli's Avatar
ECU: STANDARD
I'm sorry I did not see the link .... now I send him an email.
thanks Kam
Old 16-02-2013, 05:01 PM   #30
Punx
Punx's Avatar
CC: 1797
Received one of these myself recently thanks to the info Kam provided. I can defiantely say the quality of work is worth the money. Just gotta see if it fits now!
Punx is offline   Reply With Quote
