Old 14-11-2009, 03:43 PM   #1
DVO
DVO's Avatar
ECU: Chipped
Default Mizuki Clubman Turbo
I think this is the time to open a new thread here, because last week I finally started my own Suzuki conversion. I have been reading along already for a while getting ideas how to tackle this.
The donor car will be a 1973 Clubman with polyester front. I built this car years ago to be fitted with a Metro Turbo engine. Unfortunately I blew up the engine after 200 kms. I was so fed up with that that I sold the car to a friend 3 years ago.
This year he said that he was going to sell the car and very quickly I decided to buy the car back to turn it into a street/circuitracer with A-series engine. But shortly after I that talked to somebody who was going to do a Suzuki conversion.
First he was going to do the subframe for me, but due to circumstances that never materialized. By then I already bought a wrecked Suzuki Swift Gti followed by another one a bit later.
The only solution was to start myself. I can do some welding but I am not an ace at it, the result maybe does not look that great always, but I think strong enough.
When the decision was made to give it a go I decided to go a step further and bought a complete turbo set-up. So the project will be converting a 1275 Mini Clubman into a Mizuki Clubman Turbo.
The donor car:
We started by welding a jig around a standard Mini subframe:
Then cutting off the not needed parts from the subframe and seamwelding a lot of joints for extra strenght.
Working on the fixings op the bottom arms:
How it looks now:
Next week i will continue working towards the front. Because of the turbo the front bar has to be low I think but will see what is the most useful. I have a clubman front so a bit more space to work with than under a roundnose.
Dennis
Old 14-11-2009, 06:01 PM   #2
speedy
speedy's Avatar
ECU: standard,for now
thats a good start.
keep those progres pics coming...
the wheather is perfect to be in the shed
new engine is done...
Old 14-11-2009, 06:05 PM   #3
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
very nice, looking forward to the end result!
Old 14-11-2009, 06:17 PM   #4
Welder
Welder's Avatar
ECU: Standard, but chipped
Hit the road DVO!
Car status: Bought a new shell!
Welder is offline   Reply With Quote
Old 14-11-2009, 06:34 PM   #5
speedy
speedy's Avatar
not yet.... build a mini first...
jasper.... how far are you now...?
Old 17-11-2009, 04:30 PM   #6
DVO
DVO's Avatar
ECU: Chipped
Today en yesterday made good progress on the subframe. The bottom part is now done. Have to finish welding and will redo the left part because I think it is stronger when I weld it against the front beam instead of on top of it.
Today I got the enginesupport rubbers so I can continue also with making the engine mounts. Will be a lot of fiddling around I guess from what I heard.
Dennis
Old 18-11-2009, 05:22 PM   #7
DVO
DVO's Avatar
ECU: Chipped
Today not as much progress as I would like, because I made a mistake with the alignment of the bottom arms. That took a while, but now that is sorted out too. Changed the left hand bottom of the frame a bit and welded in the tower to front bars.
Dennis
Old 18-11-2009, 05:24 PM   #8
speedy
speedy's Avatar
nice and tidy...
Old 21-11-2009, 02:22 PM   #9
DVO
DVO's Avatar
ECU: Chipped
Yesterday and today worked on the enginemounts. I think I got it more less right. I am very happy with the result especially the one at the back gave me a lot of problems with figuring out how to do that.
I wanted that as high as possible to prevent the tilting of the engine but also supported as much as possible because it gets a lot of strains on it.
When I got al in I think I forgot something. The engine is level, but it is not straight in the subframe. How is it possible to measure that, because there are not really fixed points on the back of the engine to measure from.
I was thinking of taking off the inlet because then I have a straight line on the cylinderhead and then measure along the back of the subframe. Somebody any other suggestions?
Dennis
Old 21-11-2009, 04:43 PM   #10
Spiyda
Dennis
what we did ....
temporarily fit a length of wood to the exhaust manifold mounting surface... so that it sticks out both sides of the engine .. lined up with the studs or ports (you can block it off a bit to clear the cam belt cover) then measure back to the bulkhead cross member or subfram tower mounts
you can use the same thing for getting it level too
Old 21-11-2009, 06:21 PM   #11
DVO
DVO's Avatar
ECU: Chipped
Thanks, that is a good suggestion, will try that next time. Getting the engine level is not really the problem but it being aligned well is important I think.
Dennis
Old 21-11-2009, 06:27 PM   #12
Spiyda
Dennis
one thing , we mounted the engine so that the driveshafts werte equal lengths...if I were doing this again, I would have dissimilar lengths and mount the engine as far to the passenger side as possible (whichever side it is), it will make evening up the corner weights easier.
Old 21-11-2009, 08:16 PM   #13
DVO
DVO's Avatar
ECU: Chipped
Already read your remark about that so I did not take into account the lengths of the driveshafts. First wanted to aim for equal length, but what I understand does not prevent torquesteer anyway so why bother and make it more difficult than necessary.
Dennis
Old 23-11-2009, 04:42 PM   #14
DVO
DVO's Avatar
ECU: Chipped
The engine is now in straight. I can now start on putting on the alternator (will do that the Minigarage way I think) and putting in the suspension to get some measurements on the driveshafts.
Dennis
Old 24-11-2009, 04:26 PM   #15
DVO
DVO's Avatar
ECU: Chipped
Today worked on the alternator. Used the way Minigarage is doing it and that works well. Also found in the garage a bracket from an alternator that I adjusted a bit and the result is perfect. Nicely in line and easy to tension.
Dennis
