Old 10-05-2018, 03:48 PM   #886
Did the mk1 action day at blyton again last weekend, was a great day, did loads of laps of the track (it was quiet all day!) and gave the car a thorough workout. Only had to stop as i had worn the tyres out! The lump of rubber behind the engine mount has completely cured the wheel hop i was getting last year and along with the rear ARB and Kyb dampers i could corner much harder than before. Theres still a bit of body roll which could be cured by lowering and some red dot cones on the front but I will live with it for the sake of comfort on the road. No problems with the car, looking forward to wales now
41228419994_ae1a757652_h by garrywadey, on Flickr
I was told it was lifting a rear wheel off the ground on the tight corners, arb definitely working then!
Old 10-05-2018, 04:53 PM   #887
Well done Gaz.
No video?
Old 10-05-2018, 07:57 PM   #888
Well done, was interested in how you got on!
Old 10-05-2018, 11:02 PM   #889
Good stuff , Wales next? Within 1 hour you will want to remove your newfound aid ,
Old 12-05-2018, 07:22 AM   #890
no video this year as i couldn't be bothered, wish i had now so i could compare how much quicker the car was. I was able to accelerate much sooner and harder coming out of corners as i wasn't getting the wheel hop and i was going in to corners much faster as there was less body roll and the tyres weren't rubbing.
Old 15-06-2018, 09:18 PM   #891
I was quite happy with the cooper s calipers but a bargain came along and I couldn't resist:
2018-06-15_06-30-25 by garrywadey, on Flickr
Kad 4 pots, they were second hand but never used and a very very good price, they even came with some carbon metallic pads (£90 new!). They just fit under the steel cooper s wheels with a 6mm spacer. They are ridiculously light compared to the standard calipers and they look massive. Braking is significantly better - the standard calipers were good with decent pads but these are much better than i ever expected even with mintex standard road pads
Old 15-06-2018, 09:28 PM   #892
They look very well looked after, not Matthew Skidmoreís old ones are they? I see heís just got some 6 pots.
Old 15-06-2018, 09:34 PM   #893
not sure, I got them from a bloke in Warwickshire, he did say he did a deal with some 6 pots he had so could be
Old 26-06-2018, 09:01 AM   #894
With the wales track event cancelled I decided to still drive over to meet up with some of the lads. Was well worth it, it was a 4-5 hour drive (i did over 12 hours of driving in 2 days) - the first bit was a bit boring but the further into wales i got the better the roads got and I really enjoyed the drive. The mini was great and ate up the miles, it was a good test of how comfortable it was for longer journeys. I got out the other end feeling no more tired than if i had gone in the daily. I'd happily drive it across Europe! Also returned impressive mpg figures too - well over 50mpg
DSC_0096 by garrywadey, on Flickr
2018-06-24_05-14-15 by garrywadey, on Flickr
DSC_0084 by garrywadey, on Flickr
2018-06-24_05-13-28 by garrywadey, on Flickr
DSC_0076 by garrywadey, on Flickr
Old 26-06-2018, 10:14 AM   #895
Default My k mini - Ultimate Retro Sleeper
Handles most speed bumps well too!
Was great to get out in your car, it really reminds me of how people react when they see what they believe to be a standard looking Mini.
Itís hard to judge how quick the car actually is with the VVC, I wouldnít have said it felt any different to a 143, 160 or even when I had 180bhp and VVC, the power is delivered so smoothly that itís difficult to really feel any extra power but the numbers speak for themselves and I used to notice I was getting into corners faster than I used to when I was making upgrades from my standard 143 engine.
It really is great little car and I love how youíve gone about putting it together and took care of the little details.
Old 26-06-2018, 10:52 AM   #896
cheers, to be fair I never gave it full beans with you both in the car and without trying to offend you too much the extra weight of two extra passengers definitely makes a big difference! The flexibility of this engine is the best thing, on roads like that being able to leave it in 5th and pull from 1500 rpm makes it a relaxing drive until you open it up
Old 26-06-2018, 11:52 AM   #897
You calling me fat?! We said you were a trouble maker
It really is a great little car, put a snails on my face without evening being behind the wheel.
Old 26-06-2018, 11:52 AM   #898
4 pots , about time,
Did it rub with danno in the back lol
Old 26-06-2018, 12:08 PM   #899
only when we hit a speed bump at a silly speed (i didn't see it coming- it was camouflaged the same colour as the road...)
Old 26-06-2018, 02:15 PM   #900
Cool , normal, I asked coz the head shaped bump in roof
In the picture , boom!!
