Old 03-06-2018, 08:49 AM   #1
mm man
Default Blown compressor capacitor??? Help
Just got my mini ready for paint and boom goes the compressor
Can any one help itís a 4 hp twin pole 240v single phase motor . I fitted a new capacitor and that lasted 1 minute then boom . Can any thing other than the motor cause this to blow abit reluctant to buy a new motor if something on the compressor would cause it to blow ?? Pump it free moving ! And when it blow yesterday there was no pressure in tank as it only ran for less than a minute .
Help please as mini is desperate for itís top coat .
Old 03-06-2018, 06:08 PM   #2
VTEC JON
Default Compressor motor
Hi, I work on compressors everyday, the capacitor you fitted was it the same micro farad rating?, if so I would say that you need to get a rewind of the motor, sounds like there is a problem with the windings, there is nothing else that would cause the capacitor to blow.Donít know where you live but Iím sure there will be a Motor rewind company local.
VTEC JON is offline   Reply With Quote
Old 03-06-2018, 06:41 PM   #3
mm man
Thanks for your reply
It was rated 90uf and the one a local compressor shop got me one rated 80-100uf ó 250v
The plate on my motor reads 90uf ó 450v ?
Should the one I fitted be 450v ? even tho it on a 240v 30amp ring
Again thanks for your help
Old 03-06-2018, 06:46 PM   #4
stun538
The 240v rated ones are usually just used for starting the motor and are switched out at 2/3 ish of full speed. You need a 450v rated capacitor
stun538 is offline   Reply With Quote
Old 03-06-2018, 08:02 PM   #5
mm man
Thanks so would this new one of blown because it was 240v ? Only ?
Or because of another issue with the motor as said before ie windings
Old 04-06-2018, 05:08 AM   #6
I had a similar problem a couple of years ago, blew the capacitor replaced it like for like and it blew again, I found it cheaper to replace the 3hp single phase motor than get it re-wound.
Old 04-06-2018, 11:22 AM   #7
mm man
Thanks for the replies it now looks like the shop gave me the wrong capacitor they gave me a 250v start one instead of a 450v start and run type . I had taken the motor apart away to have a look at the widings no black marks and no burnt smell so the shop is giving me the correct type ( free of charge there mistake)and fingers crossed.
Old 17-06-2018, 08:56 PM   #8
mm man
Fitted a new 450v start and run capacitor and look what happened
TOP COAT !!
Old 21-06-2018, 12:30 AM   #9
stun538
Nice!
