Old 28-05-2018, 08:02 AM   #1
Blonda
CC: 1.6
ECU: PGM-FI OBD-1
Default steering racks
Does anyone know if a Metro rack will fit straight into a mini and does it give a bit more throw/travel?
Blonda is offline   Reply With Quote
Old 01-06-2018, 07:56 AM   #2
Blonda
CC: 1.6
ECU: PGM-FI OBD-1
Guess not then...
Old 01-06-2018, 08:44 AM   #3
Which metro rack? Austin Metro is the same width as a Mini rack, Rover Metro is 4" wider due to the revised sub frame.
Old 06-06-2018, 07:08 AM   #4
Blonda
CC: 1.6
ECU: PGM-FI OBD-1
Default Thanks
The reason I want to know is I have built a Honda VTec Mini and moved rack back about 30mm. I put on the longer Metro arms (hubs) but this means the steering doesn't give me full lock because its moved back a bit. So wondering if the metro rack (early one) might give a bit more travel and be a direct fit with a standard mini one.
Cheers.
Old 06-06-2018, 06:32 PM   #5
Cheers.
Best be checking bump steer then, as could be really bad now..
Old 07-06-2018, 08:16 PM   #6
gonk43
gonk43's Avatar
CC: 1.6
ECU: Honda 0BD1
I think i have got a brand new metro rack in my shed.
Will try and measure this weekend.
gonk43 is offline   Reply With Quote
Old 12-06-2018, 08:32 PM   #7
Blonda
CC: 1.6
ECU: PGM-FI OBD-1
Gonk43 appreciate that mate, also are the mountings the same as standard mini.
Old 13-06-2018, 06:35 AM   #8
vfast
CC: 15
you will have to make the rack fit as the mini rack bolts the body of the car and the metro rack bolts to the subframe total different but can be done you r getting into a dark area when your messing with the lengths of the drumsticks
best to use a metro rack with orange band and bolt it to the frame that will leave steering as it should be
vfast is offline   Reply With Quote
Old 13-06-2018, 07:13 AM   #9
Blonda
CC: 1.6
ECU: PGM-FI OBD-1
Rack with orange band, is that the early one that should bolt straight in to mini?
Old 13-06-2018, 07:08 PM   #10
vfast
CC: 15
Default rack
no its either mgf or metro just under 3 turns lock to lock
Old 18-06-2018, 03:08 PM   #11
gonk43
gonk43's Avatar
CC: 1.6
ECU: Honda 0BD1
Sorry Blonda, cannot find it. I had a shed clearout a while back, and it looks like it went.
The rack i have in there at moment measures 96cm tip to tip. This i think is my old mini rack i replaced with a sportpack.
Pretty sure the metro was a bit longer.
gonk43
Old 29-06-2018, 07:16 AM   #12
Blonda
CC: 1.6
ECU: PGM-FI OBD-1
Thanks anyway, so what is a sportpack?
Old 29-06-2018, 07:30 AM   #13
A steering rack from a Sportspack Mini (13 wheels) which is exactly the same as a normal Mini rack except it has a reduced lock to stop the bigger wheels rubbing.
