Old 20-02-2018, 12:32 PM   #1
Swiftmini
Send a message via MSN to Swiftmini
Default Calling all suzuki gurus
I need help coming up with a list of electrical parts that I need to put a twin cam into my justy.
I have a complete, unmodified 2001 justy.
I also have the following mk2 g13b stuff.
1 complete loom with ecu.
1 x engine with inlet with throttle body
1 x alternator
1 x starter motor
I know I'm missing a G13b coil pack, dizzy and maf sensor. Are there any other bits that I'll need to source, to be able to get this engine running in a justy? Will the mk2 swift loom be easily adapted into the 2001 justy.
If it is too much effort finding the bits, I'll probably fit Ms2 (that I have already) then I can easily go turbo or itb's in the future.
Kev
These days I have :- s13 200sx driftcar with rb25det + big turbo. Also I have r32 4 door drfitcar with an sr20det and hks turbo kit circa 350-380hp. Also I have a k10 micra with cg13de on twin dcnf webers.Soon to be started rat elf with either 1310cc a series or a cg13 micra lump. Nissan FTMFW :D
Swiftmini is offline   Reply With Quote
Old 21-02-2018, 03:22 PM   #2
Hayling mini
Hayling mini's Avatar
CC: 1340
ECU: Haltech
Matt Green messaged me to answer this, don't come on here much now.
Not sure which bits you have on your engine ?
Coil pack, dizzy & MAF will be needed, also its handy to have the pipe that comes off the throttle body that houses the MAF. You will need a GTI brake fluid reservoir, the justy one will foul the inlet unless you reverse it.
Mk2 loom will be a pain when it comes to the interior, plugs are all different for the dash & indicator stalk etc. You will need a wiring diagram for Mk2 & mk3 loom. Good luck with it
Old 22-02-2018, 02:06 PM   #3
cheers jerry
Old 22-02-2018, 02:27 PM   #4
Swiftmini
Thankyou Jerry and Matt. Looks like it'll be easier to go for megasquirt and just remove everything I don't need. It is a pain in the butt that the engine looms aren't seperate.
I may alter the inlet or put a bias pedal box in there instead
Old 22-02-2018, 02:28 PM   #5
Jerry loves megasquirts !!
Old 22-02-2018, 09:28 PM   #6
99fusion
* searches for “alternative” megasquirt results *....
Indeed! who doesn’t love a good fountain?!
