Old 26-12-2013, 02:27 PM   #61
sirkieran_1986
Was 300 plus vat . Hardened , balanced . Fit perfectly
www.kjbfabrications.webs.com
sirkieran_1986 is offline   Reply With Quote
Old 30-12-2013, 09:16 PM   #62
sirkieran_1986
Talking
bit more work done . rear seats . boot floor carpeted . brakes set up . drive shaft fitted . quick test drive . started lining front panels up
Old 31-12-2013, 07:43 PM   #63
sirkieran_1986
ttps://
Old 31-12-2013, 08:04 PM   #64
welderman
welderman's Avatar
Looking good there fella
welderman is offline   Reply With Quote
Old 31-12-2013, 10:02 PM   #65
sirkieran_1986
Cheers .
Old 31-12-2013, 11:31 PM   #66
Mini-khaos
ECU: Spoon ecu vtec 5,100 - 9,000
Sweet looks ace dude
Mini-khaos is offline   Reply With Quote
Old 02-01-2014, 07:51 PM   #67
welderman
welderman's Avatar
Good catching up today. Looks good in the flesh that roof
Old 02-01-2014, 11:14 PM   #68
sirkieran_1986
Cheers pal . Give us a shout when u doin that rad and will horlicks down with arches . Will have a look at yr new mini too .
Old 02-01-2014, 11:28 PM   #69
welderman
welderman's Avatar
Should have the ally rad welded Monday. Probably do it at dinner
Old 25-10-2014, 08:02 PM   #70
sirkieran_1986
time to start back on this
Old 25-10-2014, 08:28 PM   #71
sirkieran_1986
Old 25-10-2014, 10:44 PM   #72
minimuscle
ECU: KPro
ahh forgot about this one
minimuscle is offline   Reply With Quote
Old 10-03-2018, 09:57 AM   #73
stickerbomb
Started prepping the boby last few weeks . Been mad bizzi making 16v subframe and working on other people builds
stickerbomb is offline   Reply With Quote
Old 19-03-2018, 02:01 PM   #74
miniphil30
ECU: Erm none yet
You back Kieran?
miniphil30 is offline   Reply With Quote
Old 21-06-2018, 08:02 PM   #75
stickerbomb
Yes pal . Been bizzi building subframes . But had a good few hours on painting estate
